I have experienced and seen this problem before, if you have access to the server, try to go into the bin folder of your Umbraco installation, and see if you can find a dll named. Umbraco.Forms.Core.dll If so, try to delete it, and then see if your site is up and running again.
Maybe you also need to search your webconfig for references to Umbraco.Forms.CodeFirst, and remove this.
Contour crashed my site on uninstall
I just uninstalled Contour and then my site doesn't work any more... Please help
See the error I get on this link:
http://www.pilotskolen.com
Cana ny one please help me out here, I am desperate to get the clients site up and running again.
Hi Inmedia,
Hope this helps,
/Dennis
Hi Dennis
Thank you... That did the trick :)
Hi Inmedia,
You are welcome, glad that I could help you out :-).
/Dennis
