  • Tim 1193 posts 2675 karma points MVP 5x c-trib
    Dec 08, 2009 @ 13:29
    Tim
    Bug in Session/Cookie code
    I've spotted what appears to be a bug in contour. If you insert the placeholder for a cookie into the email template as part of a workflow send email item, for example [%myCookie], and the cookie doesn't exist for some reason (say it hasn't been set, has expired, user has cookies off), then the site throws a null reference exception, as it's not checking if the cookie exists before it gets the value.
    I've not tested it on the main site yet, so it may be the
    umbraco.BusinessLogic.StateHelper.GetSessionValue
    function that needs to check the cookie exists, or its one of the workflowservices methods.
    Dec 08, 2009 @ 13:39
    Tim
    It looks like its the GetSessionValue function (same issue for the GetCookieValue function).
    Is this by design? I'd normally check that the session/cookie existed and return string.empty if its no there, precisely to avoid these kind of errors, as there's all sorts of reasons why a cookie might be missing.
