I've installed Contour 3.0.21 into Umbraco 6.1.5 and I'm not seeing any nodes appearing in the tree:
I installed the .zip through the back-office under "Install local package" and it told me it was a success!
Hope someone can help.
Rick
Hi Rick
Have you checked the user section and made sure that your user has been granted access?
If the user has access then try and have a look in the /app_data/logs file to see if it reveals any errors perhaps?
Comment author was deleted
Can you check the /config/trees.config file, do you see any contour related entries in that one? Otherwise you'll need to manually add those
<add initialize="true" sortOrder="0" alias="forms" application="contour" title="Forms" iconClosed="legacy" iconOpen="legacy" type="Umbraco.Forms.UI.Trees.LoadForm,Umbraco.Forms.UI" />
<add initialize="true" sortOrder="1" alias="formdatasources" application="contour" title="Data Sources" iconClosed="legacy" iconOpen="legacy" type="Umbraco.Forms.UI.Trees.LoadDataSource,Umbraco.Forms.UI" />
<add initialize="true" sortOrder="2" alias="formprevaluesource" application="contour" title="Prevalue Sources" iconClosed="legacy" iconOpen="legacy" type="Umbraco.Forms.UI.Trees.LoadPreValueSource,Umbraco.Forms.UI" />
<add initialize="true" sortOrder="5" alias="formssecurity" application="users" title="Contour security" iconClosed="legacy" iconOpen="legacy" type="Umbraco.Forms.UI.Trees.LoadFormsSecurity,Umbraco.Forms.UI" />
Guys - thank so much for the quick responses!
Tim, this was the problem, there were no entries for Contour in there - once I added them in, the Contour nodes re-appeared!
Thanks again,
Super, glad you got it up and running now :)
Nodes not appearing in Contour section
Rick
Hi Rick
Thanks again,
Rick
