  • JME 14 posts 61 karma points
    Oct 27, 2014 @ 19:18
    JME
    Is there a way to add a "like/dislike" counter to comments records displaying from contour?
    We are using a comments form in contour and displaying approved comments back to our website.  We would like to incorporate a like/dislike button and counter for each of the comments.
    Has anyone else done this?  Would appreciate any information on how to acheive this.  (do not want to link to a facebook page)
  • Comment author was deleted
    Oct 28, 2014 @ 10:10
    Well you can customize the form views http://our.umbraco.org/projects/umbraco-pro/contour/documentation/Developer/Custom-Markup/
    and you can then add the like/dislike buttons
    then it's just a bit of custom code to make that work, using an api controller and a custom table...
