  • Matthew Hardesty 22 posts 73 karma points
    Oct 29, 2014 @ 04:15
    Matthew Hardesty
    Failed to save form + Errors with 3.0.21, 3.0.22WIP, 4.0WIP
    I have the same problem that Stephen mentions in his post and have attempted to address it with a variety of methods. I've listed my current setup, a description of my issue, and my attempts to resolve it (without success) below.
    My Setup
    Umbraco version 7.1.6 assembly: 1.0.5350.25714
    Umbraco Contour 3.0.21, 3.0.22WIP, 4.0WIP.
    .NET Framework version V4.5
    Description of the issue
    When creating a form, I am eventually (quickly) unable to save the form after adding/modifying/deleting a field. This affects version 3.0.21 and 3.0.22WIP as of 10/28.
    The issue isn't limited to a specific type of form field. Regardless of what form fields I edit (and even if I'm simply saving an existing template), I'm unable to save changes to labels, field removals, etc. Stephen describes the issue well.
    Inspecting the header response, I see:
    {d: false}
    My trials are listed below:
    Reinstall 3.0.21
    In an attempt to reinstall the plugin, I uninstalled 3.0.21. The uninstall script leaves an umbraco form dll in the bin folder and two references in the web.config file causing the site to break completely with a YSOD on both the frontend and admin panel.
    Thankfully, after deleting the dll file and web.config references to umbraco.forms, I was able to access the site again. I reinstalled the current version and the issue persists.
    Edit Web Config
    Based on a Google search, I tried adding the following to the web.config file per this article. The modification had no effect on my ability to save the form regardless of which version of contour/forms I had installed.
    I also tried the following (which also did not resolve the issue):
    Install Build 3.0.22WIP
    I have tried reinstalling using the latest build (3.0.22WIP). That specific build does not include the link to Contour form editor in the admin.
    I made a guess at the link ({siteurl}/umbraco/contour) and was able to see the form editor. However, the form list was not present in the middle column of the admin panel.
    Using that build, I was entirely unable to save any forms at all regardless of whether I used a template or created a form from scratch.
    Install Build 4.0WIP.4.0.0-Build.50.zip
    I have tried installing Umbraco Forms ver. 4.0WIP using UmbracoForms.package.4.0WIP.4.0.0-Build.50.zip. After installing, the forms link is present in the left navigation of the admin menu. However, there are no options to create a form. What I see, instead, is the following error:
    Could not load control: '/umbraco/plugins/umbracocontour/formsdashboard.ascx'.
    Error message: System.Web.HttpException (0x80004005): The file '/umbraco/plugins/umbracocontour/formsdashboard.ascx' does not exist. at System.Web.UI.Util.CheckVirtualFileExists(VirtualPath virtualPath) at System.Web.Compilation.BuildManager.GetVPathBuildResultInternal(VirtualPath virtualPath, Boolean noBuild, Boolean allowCrossApp, Boolean allowBuildInPrecompile, Boolean throwIfNotFound, Boolean ensureIsUpToDate) at System.Web.Compilation.BuildManager.GetVPathBuildResultWithNoAssert(HttpContext context, VirtualPath virtualPath, Boolean noBuild, Boolean allowCrossApp, Boolean allowBuildInPrecompile, Boolean throwIfNotFound, Boolean ensureIsUpToDate) at System.Web.UI.TemplateControl.LoadControl(VirtualPath virtualPath) at Umbraco.Web.UI.Umbraco.Dashboard.UserControlProxy.OnInit(EventArgs e)
    At this point, I can certainly say that I've invested a lot of time encountering errors and trying to troubleshoot a paid plugin. I'm willing to attempt a workaround or a fix, but I'm very frustrated that this is happening.
    I understand that the plugin is still in development, but it fails spectacularly at its primary purpose.
    What do I have to do to get this plugin to work?
    Oct 31, 2014 @ 20:25
    Matthew Hardesty
    Following up on this post. The issue seems to be resolved in the most recent release 3.0.22.
  • Comment author was deleted
    Nov 03, 2014 @ 09:45
    Great thanks for the update!
    Nov 26, 2014 @ 03:50
    Matthew Hardesty
    Tim -
    Sorry to say - looks like it's not resolved. I still get the error on the new version. I'm only able to create the simplest of forms before it begins to throw the error.
    I keep seeing references to a revamped / rebranded, "Umbraco Forms" plugin. Is there any chance of a release in the near future?
    Matthew Hardesty
    Sorry for double post:
    I meant to add - I don't mind sharing my code / setup with you if you want to see it. Let me know.
