When you are adding conditions to a field within the Contour editor there is a dropdown which allows the user to select a field as the source of the condition. If you are creating a large multi-step form then this shows the conditions from all form pages which makes it quite difficult to locate the correct field, especially if some forms had similar/same field names.
Therefore my question is, is there any way of changing the dropdown so it only shows available fields from the page you are currently editing?
Okay, so is there anyway of altering it so that there is a checkbox which when clicked only shows the conditions for the page you are on, and if unchecked shows all, I am just aware that with the sheer size of the workflow I am dealing with here there will be a good 200-300 fields in that dropdown!!
Conditions field selector dropdown
Comment author was deleted
Nope there isn't since you can setup conditions between pages...
Being able to have conditions between pages would be super useful, as would being able to move fields between pages.
