ERROR CREATING CONTROL FOR NODETYPE: formssecurity
I had previously installed Contour, but after uninstalling the package and then reinstalling it again I get a ASP.NET error when I go to Contour Security and 'Create'
Umbraco v4.0.3
Win2k3
Exception Details:
System.ArgumentException: ERROR CREATING CONTROL FOR NODETYPE: formssecurity
Source Error:
Stack Trace:
[ArgumentException: ERROR CREATING CONTROL FOR NODETYPE: formssecurity]
I am also getting this error, and all my configurations are exactly as described above. Not only am I getting the formssecurity error, though-- my whole CMS has blown up as a result of Something in Contour. In every module, I can only see the root node, and nothing under it. NIo page that has a FORM on it will display. I get only this error, everywhere:
Umbraco.Forms.Core.Common.ProviderException: No provider with id '3f92e01b-29e2-4a30-bf33-9df5580ed52c' found
I also get this error when clicking on any users in the Contour Security folder in the Users tab, and when I click on Anything on the Contour tab.
What does this error Mean? And why did it come out of nowhere? I had my contour forms on my site rnunign for a month or so witrhout issue and then today I log in to Umbraco and I can't see Anything. The reason I think its contour is because every page on my published site is Okay, Except for the Contact Us form, which uses a Contour macro. That form is completely gone.
The string "3f92e01b-29e2-4a30-bf33-9df5580ed52c" actually EXISTS in two files. Javascript files. One is umbraco/plugins/umbracoContour/scripts/umbracoforms.js and the other is data/13622b46-3030-4a9c-a1c9-32c326db5555/ef5974d7-5771-4d37-92ad-aff20b014e00.js. This second one, what the heck IS this file??
I am lost. No one touched anything in Contour at ALL, and all of a sudden the CMS won't display ANY forms.
I cannot even uninstall Contour because I can't see any nodes beneath the root node in any of the modules, including Developer, so I can't see the "Installed Packages" folder.
The error you get when trying to create something in the contour users tree is because you are no supposed to be able to create anything there. The context menu "create" item is a bug, you should not be able to create anything. All users who have access to the contour application will automaticly be added to that tree, and therefore, there is no reason to create anything.
@Garrett, the oddly named js file is a backup from the package you installed contour from, it keeps the files incase something in the install suddenly stops, and it has to resume. And as talked about on email, your issues are because of a version mismatch on the AjaxControlToolkit.dll, the fix is mentioned in the installing documents under "known issues"
I'm running Contour on beta 4.1 with some of the samme issues:
When creating a form from a template I get the following error: No provider with id '3f92e01b-29e2-4a30-bf33-9df5580ed52c' found
When trying to add a field I can't select type (the dropdown is empty), I have updated the web.config as menitioned in the install guide, and followed each step manually, and everything seems fine. Even double checked the version of the AjaxControlToolkit.dll to mach the web.config update.
When trying to add a field in Firefox the green field "creator" flicker and dissapear. Then errorconsole gives the following js error: Error: f is undefined Source File: .../umbraco/plugins/umbracoContour/scripts/jquery.dd.js Line: 7
I gues this has to do with the beta version, but would be nice if anybody knows about a fix for it :-)
I am having the same problem. Got Contour last week, installed and registered with my username/pass.
On my local system the site works fine, but on the live server this is what I get on the contour pane:
found
Description: An unhandled exception occurred during
the execution of the current web request. Please review the stack trace
for more information about the error and where it originated in the
code.
Exception Details: Umbraco.Forms.Core.Common.ProviderException:
all other cms panes are blank, as if there is absolutely no content...
Oddly enough he hasn't really changed but
The same host runs another site based on umbraco, works perfectly without Contour.
I have just updated a site from 4.0 (.Net 2.0) to 4.5.1 (.Net 4.0). After the update I have manually re-established the package files based on the info in installedPackage.config file. But I get the same error when I try to insert a Contour Form in a document
And in Contour the tree does not contain the forms previously created in contour:
And I get the following exception when trying to create a new form:
No provider with id 'e96badd7-05be-4978-b8d9-b3d733de70a5' found
code.
Exception Details: Umbraco.Forms.Core.Common.ProviderException: No provider with id 'e96badd7-05be-4978-b8d9-b3d733de70a5' found
Source Error:
Stack Trace:
[ProviderException: No provider with id 'e96badd7-05be-4978-b8d9-b3d733de70a5' found] Umbraco.Forms.Core.Common.ProviderCollection`1.GetProvider(Guid id) in d:\TeamCity\buildAgent\work\39da791f9304089a\Umbraco.Forms.Core\Common\ProviderCollection.cs:27 Umbraco.Forms.Data.Storage.FormStorage.InsertForm(Form form) in d:\TeamCity\buildAgent\work\39da791f9304089a\Umbraco.Forms.Core\Data\FormStorage\FormStorage.cs:162 Umbraco.Forms.UI.Tasks.FormTasks.Save() in d:\TeamCity\buildAgent\work\39da791f9304089a\Umbraco.Forms.UI\Tasks\FormTasks.cs:99 umbraco.presentation.create.dialogHandler_temp.Create(String NodeType, Int32 TypeId, Int32 NodeId, String Text) +1045 umbraco.presentation.create.dialogHandler_temp.Create(String NodeType, Int32 NodeId, String Text) +71 Umbraco.Forms.UI.Dialogs.createForm.sbmt_Click(Object sender, EventArgs e) in d:\TeamCity\buildAgent\work\39da791f9304089a\Umbraco.Forms.UI\Dialogs\createForm.ascx.cs:29 System.Web.UI.WebControls.Button.RaisePostBackEvent(String eventArgument) +154 System.Web.UI.Page.ProcessRequestMain(Boolean includeStagesBeforeAsyncPoint, Boolean includeStagesAfterAsyncPoint) +3691
Version Information: Microsoft .NET Framework Version:4.0.30319; ASP.NET Version:4.0.30319.1
Have anybody experienced something like this and if so have you found a solution?
Umbraco v4.0.3
Win2k3
Exception Details:
Source Error:
Stack Trace:
umbraco.cms.presentation.Create.Page_Load(Object sender, EventArgs e) +415
System.Web.Util.CalliHelper.EventArgFunctionCaller(IntPtr fp, Object o, Object t, EventArgs e) +14
System.Web.Util.CalliEventHandlerDelegateProxy.Callback(Object sender, EventArgs e) +35
System.Web.UI.Control.OnLoad(EventArgs e) +99
umbraco.BasePages.BasePage.OnLoad(EventArgs e) +15
System.Web.UI.Control.LoadRecursive() +50
System.Web.UI.Page.ProcessRequestMain(Boolean includeStagesBeforeAsyncPoint, Boolean includeStagesAfterAsyncPoint) +627
Microsoft .NET Framework Version:2.0.50727.3603; ASP.NET Version:2.0.50727.3082
I've got the same error, any thoughts on how to resolve this.
I get the same error - any solutions?
Comment author was deleted
It sounds like the entry in the /umbraco/config/create/ui.xm file is missing.
Please check the Install guid on page 6 (Adding configuration to ui.xml)
http://umbraco.org/pro-downloads/Contour-Install-Guide.pdf
Ow
You don't need to create anything in the Contour Security tree, every user that has access to Contour will be added automaticly.
I need some help. Please!
Garrett
In both of them, the line is:
$("#fieldtype option:[value='3f92e01b-29e2-4a30-bf33-9df5580ed52c']").attr('selected', 'selected');
Help,
Garrett
Just to clarify
http://umbraco.org/products/umbraco-contour/help-and-support/installation-guide.aspx
/Per
Line: 7
Hi Kristian,
Yes these issues will be resolved with the stable version of 4.1
Description: An unhandled exception occurred during the execution of the current web request. Please review the stack trace for more information about the error and where it originated in the code.Exception Details: Umbraco.Forms.Core.Common.ProviderException: No provider with id '3f92e01b-29e2-4a30-bf33-9df5580ed52c' found
Hi guys
Anybody found a solution for this error?
Description: An unhandled exception occurred during the execution of the current web request. Please review the stack trace for more information about the error and where it originated in the code.Exception Details: Umbraco.Forms.Core.Common.ProviderException: No provider with id 'e96badd7-05be-4978-b8d9-b3d733de70a5' found
Source Error:
Thanks a lot in advance.
Kim
Hi Kim,
Do you have the ajaxcontroltoolkit dll in the bin directory?
Tim
Hi Tim,
Thank you very much!!! That did the trick :)
Kim
Is there a way to resolve this running 4.0.3? The link Per is reffering to is dead
@Anders http://umbraco.org/products/umbraco-contour/installation-guide
hmm still got the same issue.. just found out the host is running .net 2.0, that might be the cause :-)?
