  • Ondřej Šubrt 5 posts 25 karma points
    Nov 28, 2014 @ 16:44
    Ondřej Šubrt
    Contour default values do not work
    Hi guys,
    I am using Umbraco 7.2.0 and its package Umbraco Forms 4.0.0-Build.77 and I have issue wuth default values of all components.
    For instance, I set default value of textfield in administration and the default value is not shown in frontend at all. The same issue is with checkbox and so on (in fact with all form components).
    The default value is filled in settings of the form component, but it does not reflect in frontend.
    Could anyone help me?
    Thanks in advance,
    Ondřej Šubrt
    Nov 28, 2014 @ 17:17
    Hi Ondej and welcome to our :)
    Perhaps this is a bug, which needs to be logged on the issue tracker if you don't mind? Please provide as much detail as you can like what database you're using etc. so it's easier for the HQ guys to try and recreate the issue.
    Cheers, Jan
  • Comment author was deleted
    Dec 01, 2014 @ 11:07
    Thanks for reporting :) should be fixed this week as the final is going out by the end of the week
    Dec 01, 2014 @ 11:15
    Ondřej Šubrt
    Thanks a lot for your quick response :)
    I will wait for the end of the week :)
    Dec 01, 2014 @ 13:20
    Just fixed the issue, you can fetch the latest build from http://nightly.umbraco.org/Umbraco%20Contour/4.0/
    Dec 01, 2014 @ 13:50
    Ondřej Šubrt
    It works :).
    Thanks a lot for your cooperation
    Dec 01, 2014 @ 16:53
    Sweet, thanks for confirming :)
