Hmm, that might be a bug - Not sure but I think that the idea is that when you know the id you can use something like Umbraco.NiceUrl(record.umbracopageid) - Not quite sure about the syntax though since I have not had a chance to play with Umbraco Forms yet.
But just so that you get the notion.
So I think you should file it as a bug on the issue tracker
Record data and page url in default values
I need to attatch the page url to a form posted so it will list from which page its posted.
In the documentation(contour) it lists that {record.umbracopageid} should get the current page id (Comes up blank, so doesn't work)
Is there a way to get the page url instead of just the id? The current requests url would be fine.
I'm using Umbraco 7.2.0-beta2
With the latest Umbraco Forms (4.0WIP.4.0.0-Build.81)
Hi Søren
Now using version 83, {record.ip} and {record.umbracopageid} still comes up blank unfortunately.
Would be great to have the url there, but even an Id would do.
I need to do this as well (U7.1.6, Contour 3.0.21)
{record.umbracopageid} works fine, but returns an ID (Doh), which is useless to the reciever.
Umbraco.NiceUrl(record.umbracopageid) won't do the trick...
Isn't there a shorthand tag to get the url??? it seems odd, since the url is listed in the Contour Dashboard...
Im thinking like {record.umbracopageurl}
I hate to up this thread, but seeing as Contour is a PRO package, could someone from HQ possibly answer this question?
Anyone? The silence is worrying...
