  • Anne 2 posts 22 karma points
    Dec 09, 2014 @ 15:38
    Anne
    Advise about Contour and installing
    I'm new in this forum and I need som advise for installing contour.
    At my job we have an old version of Umbraco (v. 4.0.2.1). I would like to make a sign up form and I can see that I can install Contour to do that.
    Is there something I should be aware of? I'm a little "scared" of clicking install...
    I hope someone can help me :)
    All the best,
    Anne
    Dec 09, 2014 @ 15:49
    Dennis Aaen
    Hi Anne and welcome to our,
    Since you are using an older version of Umbraco, you have to use the Contour version 1.1.19 you can find old versions of Contour here, http://nightly.umbraco.org/Umbraco%20Contour/Archive/
    And you can find the specific version that you can use for your Umbraco installation here: http://nightly.umbraco.org/Umbraco%20Contour/Archive/1.1.9/
    The Contour package is a pro product which means that you need a to order a license for Contour to use it in production, but you can run it in a test mode for try it out for your dev environment.
    You can read more about Contour here. http://umbraco.com/help-and-support/customer-area/contour-support-and-download and http://umbraco.com/products/more-add-ons/contour
    Hope this helps, if not don't hesitate to write again
    /Dennis
    Dec 11, 2014 @ 11:37
    Anne
    Hi Dennis
    Thank you for your reply og guidance! What does it mean that I need a license to use Contour - where do I get a license?
    Thanks.
    All the best,
    Anne
    Dec 11, 2014 @ 11:48
    Dennis Aaen
    Hi Anne,
    You can install and play around with Contour on your development environment, but for production to get real data when your form is submitted you need a license, if you don“t have a license then your Contour will run in trial mode, and when a user is submit the form, the data you will see is something like "Contour is in trial mode"
    You can order a Contour license here: http://umbraco.com/products/more-add-ons/contour
    Hope this helps,
    /Dennis
    Dec 11, 2014 @ 14:14
    Dennis Aaen
    Hi Anne,
    I can also see that you ask about how to install the Contour package. There are difference options to install packages in Umbraco here is http://our.umbraco.org/wiki/how-tos/packages-and-projects/how-to-install-a-package some documentation on how to install packages on Umbraco CMS. I always use the install the local package option myself.
    Hope this helps,
    /Dennis
