I can see scripts generated to test the show/hide of the conditional field. Only doesn't looke like they are being triggered, I put in some stop points Chrome debugger.
Not sure what else to check? I have reviewed other posts in this forum with that problem but haven't seen any solutions?
Conditional login not working - Contour 3.0.21, Umbraco v6.2.1
I set up a test checkbox list, so when you click 'value 2' the following text box will appear
Only it is not working on my page. It works in the preview mode.
I have added the scripts.
Anyone have any suggestions on how to fix this?
Actually shouldn't say LOGIN but LOGIC in the title...
Conditonal Logic is not working...
And figured this one out - turns out there was some conflicting javascript in the template (some ancient jquery include and some other jquery)
I moved the contour javascript includes after all that, and seems to work. Hopefully didn't break any of the old stuff!
