  • karen 186 posts 461 karma points
    Dec 11, 2014 @ 00:18
    karen
    Conditional login not working - Contour 3.0.21, Umbraco v6.2.1
    I set up a test checkbox list, so when you click 'value 2' the following text box will appear
    Only it is not working on my page.  It works in the preview mode.
    I have added the scripts.
    <script src="//ajax.aspnetcdn.com/ajax/jQuery/jquery-1.8.2.min.js" type="text/javascript"></script>
    <script src="//ajax.aspnetcdn.com/ajax/jquery.ui/1.8.22/jquery-ui.js"></script>
    <script src="//ajax.aspnetcdn.com/ajax/jquery.validate/1.10.0/jquery.validate.min.js" type="text/javascript"></script>
    <script src="//ajax.aspnetcdn.com/ajax/mvc/3.0/jquery.validate.unobtrusive.min.js" type="text/javascript"></script>
    I can see scripts generated to test the show/hide of the conditional field. Only doesn't looke like they are being triggered, I put in some stop points Chrome debugger.
    Not sure what else to check? I have reviewed other posts in this forum with that problem but haven't seen any solutions?
    Dec 16, 2014 @ 19:59
    karen
    Anyone have any suggestions on how to fix this?
    Jan 22, 2015 @ 18:52
    karen
    Actually shouldn't say LOGIN but LOGIC in the title...
    Conditonal Logic is not working...
    Jan 23, 2015 @ 19:49
    karen
    And figured this one out - turns out there was some conflicting javascript in the template (some ancient jquery include and some other jquery)
    I moved the contour javascript includes after all that, and seems to work.  Hopefully didn't break any of the old stuff!
