  • Yves Kircher 21 posts 69 karma points
    Dec 15, 2014 @ 23:35
    Yves Kircher
    Easy Calculator with Contours
    Hi, i created a simple Form for a calculator like:
    Field 1(input) Number1
      Field 2(select): +,-,*,/
    Field 3(input): Number2
    The result is stored in the contours table
    My Problem:
    After Submitting the form i want to output the resulöt of the operation
    How does that work? ( i guess some razor code )
    Dec 15, 2014 @ 23:44
    Dennis Aaen
    Hi Yves,
    Have you seen the documentation about working with data from Contour, if not take a look here, http://our.umbraco.org/projects/umbraco-pro/contour/documentation/developer/.
    As you can see you can get data from Contour by using Razor http://our.umbraco.org/projects/umbraco-pro/contour/documentation/developer/Working-with-Contour-data-in-Razor/ or XSLT http://our.umbraco.org/projects/umbraco-pro/contour/documentation/developer/Working-with-Contour-data-in-XSLT/.
    Hope this helps,
    /Dennis
    Dec 16, 2014 @ 00:32
    Yves Kircher
    Thank you very much :)
