  • James 8 posts 38 karma points
    Dec 16, 2014 @ 11:15
    James
    FormPicker for Umbraco Forms?
    Hi All,
    As I underdstand it, Umbraco Forms is the new Contour.  I understand they are different projects and codebases so since I don't see a FormPicker datatype I assume that functionality hasn't made it to Umbraco Forms yet?
    Any suggestions on how to get that functionality or will I have to roll my own?  Any help would be greatly appreciated
    James
    Dec 16, 2014 @ 11:44
    Dennis Aaen
    Hi James,
    If have installed the Umbraco Forms in your Umbraco installation, then go to Developer section if you have access to it, and in the data types folder create a new data type, give your new data type a name like form picker, and then choose the Form picker as the property editor.
    Hope this helps,
    /Dennis
    Dec 16, 2014 @ 11:53
    James
    HI Dennis,
    Thanks for that.  About 30 seconds after I submitted my question I figured it out myself.
    Feeling pretty silly right about now!
    James
    Dec 16, 2014 @ 12:03
    Dennis Aaen
    James do not feel stupid, the forum is here so that you can ask for help and get the help you needed.
    And I'm glad that I could help you out, even you have figured it out yourself.
    /Dennis
