  • Yannick Smits 321 posts 718 karma points
    Dec 18, 2009 @ 12:55
    Yannick Smits
    Using SqlServer Data source
    When using the special "Data Source" option to connect to an existing table how would I insert the record.Ip and record.membername into this table?
    Dec 18, 2009 @ 13:37
    Yannick Smits
    oh and is it possible to have multiple steps when using the Data sources approach?
  • Comment author was deleted
    Dec 23, 2009 @ 11:40
    Hi Yannick, currently it isn't possible to have multiple steps when the form is attached to a Data Source
    Dec 23, 2009 @ 18:17
    Yannick Smits
    Thanks Tim, what about my first question?
    Jan 07, 2010 @ 13:39
    Yannick Smits
    Anyone?
  • kevin 31 posts 52 karma points
    Jan 07, 2010 @ 17:09
    kevin
    I couldn't find it either, as a workaround i created a form in umbraco (this way you can have multiple steps as well) and created a workflow to save the content to an external database, this way you can retrieve the id of the inserted record and add additional logic, you can query record.membername and session/querystring values there as well.
    Let me know if you need some code.
    However, it would be great to be able to add record.Ip and record.membername to the external datasource though :-)
    Jan 07, 2010 @ 23:29
    Yannick Smits
    Hi Kevin, that would help. Can you send it to yannick(a.t)goyaweb.nl? thanks!
    Jan 08, 2010 @ 10:44
    kevin
    public
    class MyWorkflow : Umbraco.Forms.Core.WorkflowType
    public override List<Exception> ValidateSettings()
    List<
    Exception> exceptions = new List<Exception>();
    return exceptions;
    public MyWorkflow()
    this.Name = "My workflow";
    this.Id = new Guid("925f95ec-99f1-435a-ae59-89e47bbc6578");
    this.Description = "Save entries to custom table";
    public override Umbraco.Forms.Core.Enums.WorkflowExecutionStatus Execute(Record record, RecordEventArgs e)
    Umbraco.Forms.Core.Enums.WorkflowExecutionStatus sResult;
    Log.Add(LogTypes.Debug, docId,
    "record submitted with id: " + record.Id
    // get form field values by guid or caption
    RecordField rfVoornaam = record.RecordFields[new Guid("CA4705F4-CB4C-4DFE-BFD3-018F8AC97FA7")];
    RecordField rfNaam = record.RecordFields[new Guid("4717188E-E0E4-45F5-B332-1C86D59CAA21")];
    RecordField rfEmail = record.RecordFields[new Guid("B1337006-6335-4D97-BFF5-42A4EA76DE74")];
    RecordField rfOptin = record.RecordFields[new Guid("84456225-3C3C-499C-8FBD-55CBE1CF4D6A")];
    RecordField rfVraag = record.RecordFields[new Guid("3D2A2CDB-09FD-410E-BF46-C3E6445044A1")];
    RecordField rfSchift = record.RecordFields[new Guid("DA1B84A3-AE17-46B2-9DF2-FB3E50563043")];
    // get page to redirect to when user has already filled out the form before
    string strFailed = umbraco.presentation.nodeFactory.Node.GetCurrent().GetProperty("Failed").Value.ToString();
    int intFailed = Convert.ToInt32(strFailed);
    //Save
    string strFirstName = rfVoornaam.ValuesAsString();
    string strLastName = rfNaam.ValuesAsString();
    string strEmail = rfEmail.ValuesAsString();
    string strLanguage = CultureInfo.CurrentCulture.Name;
    string strQuestionAnswer = rfVraag.ValuesAsString();
    string strSchiftAnswer = rfSchift.ValuesAsString();
    Boolean blnOptIn = rfOptin.ValuesAsString() == "True" ? true : false;
    if (!string.IsNullOrEmpty(strEmail))
    // save form data
    // result contains 1 (succes) or 0 (failed)
    // output param guidNewID with guid to retrieve form data
    Result = SaveEnquete(strLanguage, strFirstName, strLastName, strEmail, blnOptIn, strQuestionAnswer, strSchiftAnswer,
    out guidNewID);
    if (Result >= 0)
    // succes!
    sResult = Umbraco.Forms.Core.Enums.WorkflowExecutionStatus.Completed;
    // redirect to page specified in umbraco
    else
    // failed!
    sResult = Umbraco.Forms.Core.Enums.WorkflowExecutionStatus.Failed;
    // set redirect to error page!
    e.Form.GoToPageOnSubmit = intFailed;
    // save guid to session
    e.Context.Session[
    "form_guid"] = guidNewID.ToString();
    return sResult;
    Hope this helps!
    Jan 08, 2010 @ 17:27
    Yannick Smits
    I'm trying to understand the code. Basically you attach this to the "When the form has been submitted" workflow event, right?
    How would you extend this example to support multi-page?
    What do you think is still the advantage of using Contour instead of building your own form?
    Jan 12, 2010 @ 11:07
    kevin
    Yeah, that's right. It works the same way for multi-page forms, you can retrieve all the fields in the submit stage of the workflow.
    I'm sure this won't be necessary anymore in future versions, for now, once you've figured out how everything works you can still gain lots of time because you only have to take care of saving data : the form can be updated, validation, multi-page is all done by umbraco
    Jan 13, 2010 @ 13:45
    Yannick Smits
    Do you know which method to override when using multi-page? I think Contour also saves partial submits.
