  • JoAs 3 posts 23 karma points
    Jan 05, 2015 @ 17:43
    JoAs
    Edit Entries with a Dropdown doesn't work
    after editing the value of a dropdwon manually under entries then there will not be the selceted value. instead a number is shown.
    for example i've got a dropdwon with sir and madame. Then i go to contour in the backend look for this entrie edit the value drom sir to madame. Then this entrie doesn't show madame instead a number is displayed.
    Can anyone help?
  • Tim 1193 posts 2675 karma points MVP 4x c-trib
    Jan 06, 2015 @ 16:22
    Tim
    Are you on an older version of Contour? What version are you using on your site?
    Jan 06, 2015 @ 17:34
    JoAs
    I'm using this Veriosn: 3.0.23-Build.20
  • keilo 568 posts 1023 karma points
    Apr 29, 2015 @ 21:01
    keilo
    Im having the same issue, using contour version  3.0.23-Build.20 on 7.1.x, when I try to Edit a submitted entry with radio-group, the radio boxes's value are not shown (not selected) therefore not allowing user to edit the submitted value.
    Any quick remedy or solution to this? many thx in advance
