  • Alex Slabukh 17 posts 77 karma points
    Jan 08, 2015 @ 17:20
    Alex Slabukh
    xpath doesn't work in path of save document
    Hi guys,
    I have the problem with publish document instantly, using xpath
    I have "Review" form with the Manual Approval functionality
    I have workflow with type Save as umbraco document
    I have multi language site, and I try to put "Review" document in a different directory, depend from page, after   approval.
    I use xpath: $currentPage/@id , but document puts in root directory
    And It doesn't working... What I do wrong?
  • Richard Barg 358 posts 532 karma points
    Jan 12, 2015 @ 20:11
    Richard Barg
    I would file a bug report. If you look at this forum since Christmas, you will notice the large number of postings - zeroes 0000000 w/no response form HQ.
    This is a feature we use all time w/Contour 4 in Umbraco 4.11. It certainly give me pause about upgrading as it isn't working in Version 7, at least for you and no one is responding.
    Jan 13, 2015 @ 05:36
    Alex Slabukh
    I fixed this problem using workflow for every localisation site and add path for directory manually.
  • Comment author was deleted
    Jan 22, 2015 @ 15:13
    Yeah best to report this on the issue tracker so it doesn't get lost, looking into a fix now :)
    Jan 22, 2015 @ 15:22
    Hmm just tested and it works fine, mind sharing some more details, maybe a screenshot on how the workflow is setup?
