  • John C Scott 473 posts 1183 karma points
    Jan 15, 2015 @ 16:01
    John C Scott
    datepicker throwing "is not valid" error on entry
    On an Umbraco 4.11 site with Contour (package version says 1.1.10) we have a date field. when any date is chosen we get the error "[field name] is not valid". You can see the error and the Contour settings in the image attached.
    Any ideas why this would happen and how we can stop this?
    Jan 15, 2015 @ 16:12
    Hi John
    What would the default date format look like in your language? Is it dd/MM/YYYY or is it something else? I think you perhaps need to dig into the Contour source code and add some data-configuration where the jquery ui datepicker is being called.
    Also...is the execution order of the javascripts set correctly? I remember that Contour by default calls them in the section rather than in before
    Jan 16, 2015 @ 10:30
    John C Scott
    Thanks Jan been having a look. However I saw some references in other threads to issues where the field was not originally of date type and changed to date type. I asked the user if this is what she'd done and yes! So she deleted the field and added a new one and it worked.
    Jan 16, 2015 @ 10:33
    Hi John
    Ok, good to hear you managed to figure out what was wrong :) I just remember I had to deal with issues regarding date formats etc. when using Contour on danish sites a year ago or so.
