  • kevin 31 posts 52 karma points
    Dec 22, 2009 @ 12:59
    kevin
    Contour sql datasource ID
    I'm using Contour 1.0.7 with an external datasource. I want to retrieve the primary key or add record.id when the data gets saved to my custom table so that I can reference it later on.
    I'm considering two options :
    Creating a workflowtype that would somehow put the record.id in a field of the external datasource. Is this possible? I only seem to be able to update the fields that are available to the user, and not the predefined values.
    Another option would be to create a custom Datasourcetype.
    Does anyone have an example of how to create a custom DataSourceType for contour? Is it possible to inherit from the Sql Datasource already provided in contour?
    Thanks for any suggestions
    Kevin
  • Comment author was deleted
    Dec 23, 2009 @ 11:31
    Hi Kevin,
    A custom workflowtype would be the easiest solution. Check the developer documentation to get started with a workflow http://umbraco.org/products/umbraco-contour/help-and-support/developer-documentation.aspx
    Dec 23, 2009 @ 12:17
    kevin
    Hi Tim,
    I've managed to create a custom workflowtype, and i can retrieve record.id. However i can't figure out how to write it to the "sql datasource". The record parameter passed to the execute function only contains the fields that are editable by the user and i don't want to change those. Can i edit the fields containing predefined values?
    Is there an example available for a custom DataSourceType and is it possible to inherit the sql datasource datasourcetype from contour? :-)
    Thanks!
    Kevin
