I am trying to write some XSLT to format the xml results in my forms that are emailed to include fieldsets in the table of data sent. I don't know if I am doing the "choose" statement correctly. Could someone help me out please?
<?xml version="1.0" encoding="utf-8"?> <xsl:stylesheet version="1.0" xmlns:xsl="http://www.w3.org/1999/XSL/Transform" xmlns:msxsl="urn:schemas-microsoft-com:xslt" xmlns:user="urn:my-scripts" xmlns:umbraco.library="urn:umbraco.library" exclude-result-prefixes="xsl msxsl user umbraco.library"> <xsl:output method="html" media-type="text/html" doctype-public="-//W3C//DTD XHTML 1.0 Strict//EN" doctype-system="DTD/xhtml1-strict.dtd" cdata-section-elements="script style" indent="yes" encoding="utf-8"/> <xsl:param name="records" /> <xsl:template match="/"> <table style="border-collapse:collapse;border:1px solid black;"> <xsl:for-each select="$records//fields/child::*"> <xsl:sort select="./@pageindex" data-type="number" order="ascending"/> <xsl:sort select="./@fieldsetindex" data-type="number" order="ascending"/> <xsl:sort select="./@caption" data-type="number" order="ascending"/> <xsl:sort select="./@sortorder" data-type="number" order="ascending"/> <tr style="border:1px solid black;"> <xsl:choose> <xsl:when test="contains(./fieldset)"> <td valign="top" style="border:1px solid black;padding:5px;font-family:Verdana,Helvetica,Arial,sans-serif;font-size:11px;background-color:#ccc;"> <strong> <xsl:value-of select="./fieldset" disable-output-escaping="yes"/> </strong> </xsl:when> <xsl:otherwise> <td valign="top" style="border:1px solid black;padding:5px;font-family:Verdana,Helvetica,Arial,sans-serif;font-size:11px;"> <strong> <xsl:value-of select="./caption" disable-output-escaping="yes"/> </strong> </td> </xsl:otherwise> </xsl:choose> <td valign="top" style="border:1px solid black;padding:5px;font-family:Verdana,Helvetica,Arial,sans-serif;font-size:11px;"> <xsl:choose> <xsl:when test="contains(.//value, '/umbraco/plugins/umbracoContour/files/')"> <a href="http://{umbraco.library:RequestServerVariables('SERVER_NAME')}{.//value}"> <xsl:value-of select=".//value"/> </a> </xsl:when> <xsl:otherwise> <xsl:for-each select="./values/value"> <xsl:if test="position() > 1"> <br /> </xsl:if> <xsl:value-of select="umbraco.library:ReplaceLineBreaks(.)" disable-output-escaping="yes"/> </xsl:for-each> </xsl:otherwise> </xsl:choose> </td> </tr> </xsl:for-each> </table> </xsl:template> </xsl:stylesheet>
XSLT Transformed Email Help
<?xml version="1.0" encoding="utf-8"?> <xsl:stylesheet version="1.0" xmlns:xsl="http://www.w3.org/1999/XSL/Transform" xmlns:msxsl="urn:schemas-microsoft-com:xslt" xmlns:user="urn:my-scripts" xmlns:umbraco.library="urn:umbraco.library" exclude-result-prefixes="xsl msxsl user umbraco.library"> <xsl:output method="html" media-type="text/html" doctype-public="-//W3C//DTD XHTML 1.0 Strict//EN" doctype-system="DTD/xhtml1-strict.dtd" cdata-section-elements="script style" indent="yes" encoding="utf-8"/> <xsl:param name="records" /> <xsl:template match="/"> <table style="border-collapse:collapse;border:1px solid black;"> <xsl:for-each select="$records//fields/child::*"> <xsl:sort select="./@pageindex" data-type="number" order="ascending"/> <xsl:sort select="./@fieldsetindex" data-type="number" order="ascending"/> <xsl:sort select="./@caption" data-type="number" order="ascending"/> <xsl:sort select="./@sortorder" data-type="number" order="ascending"/> <tr style="border:1px solid black;"> <xsl:choose> <xsl:when test="contains(./fieldset)"> <td valign="top" style="border:1px solid black;padding:5px;font-family:Verdana,Helvetica,Arial,sans-serif;font-size:11px;background-color:#ccc;"> <strong> <xsl:value-of select="./fieldset" disable-output-escaping="yes"/> </strong> </xsl:when> <xsl:otherwise> <td valign="top" style="border:1px solid black;padding:5px;font-family:Verdana,Helvetica,Arial,sans-serif;font-size:11px;"> <strong> <xsl:value-of select="./caption" disable-output-escaping="yes"/> </strong> </td> </xsl:otherwise> </xsl:choose> <td valign="top" style="border:1px solid black;padding:5px;font-family:Verdana,Helvetica,Arial,sans-serif;font-size:11px;"> <xsl:choose> <xsl:when test="contains(.//value, '/umbraco/plugins/umbracoContour/files/')"> <a href="http://{umbraco.library:RequestServerVariables('SERVER_NAME')}{.//value}"> <xsl:value-of select=".//value"/> </a> </xsl:when> <xsl:otherwise> <xsl:for-each select="./values/value"> <xsl:if test="position() > 1"> <br /> </xsl:if> <xsl:value-of select="umbraco.library:ReplaceLineBreaks(.)" disable-output-escaping="yes"/> </xsl:for-each> </xsl:otherwise> </xsl:choose> </td> </tr> </xsl:for-each> </table> </xsl:template> </xsl:stylesheet>is working on a reply...
