  • David W. 159 posts 284 karma points c-trib
    Jan 23, 2015 @ 12:15
    David W.
    Manual upgrade of Umbraco Forms
    As I happen to have som issues with the upgrading of Umbraco Forms through the backoffice, is there a way to manually upgrade/install new versions?
    Also, is thera a blog or other way to follow when new releases are availible?
    Jan 23, 2015 @ 12:20
    David W.
    Actually the back-office upgrading just updated and the upgrade seems to be working! I Believe there was just now a new version released?
  • Chris 92 posts 238 karma points
    Jan 23, 2015 @ 12:37
    Chris
    http://issues.umbraco.org/issue/CON-659
    Nope, it was fixed a few hours ago.
  • Matthew Kirschner 323 posts 611 karma points
    Feb 18, 2015 @ 16:35
    Matthew Kirschner
    I would still like to know if there is a manual upgrade path.
    Also, is there a changelog available? I'd like to know what's new/fixed before I update.
    Feb 18, 2015 @ 16:37
    Matthew Kirschner
    I found these installation/upgrade docs, but they're incomplete:
    https://github.com/umbraco/UmbracoFormsDocumentation/blob/master/Installation/index.md
  • Jamie Attwood 210 posts 508 karma points c-trib
    Mar 16, 2016 @ 20:37
    Jamie Attwood
    Backoffice Upgrade of forms is failing on Umbraco version 7.2.0 assembly: 1.0.5451.27165 with forms 4.0WIP.4.0.0-Build.84.
    How to manually upgrade? The link in the docs just 404's...
    https://github.com/umbraco/UmbracoFormsDocumentation/blob/master/Installation/Upgrade.md
