  • Jonathan Roberts 409 posts 1063 karma points
    Jan 26, 2015 @ 13:25
    Jonathan Roberts
    Contour custom TinyMCE FieldType
    We are using Umbraco 7.2 with Contour and we want to create our own TinyMCE FieldType so we can post HTML but we are getting into some difficulties. When following the code similar to the link found here : http://our.umbraco.org/forum/umbraco-pro/contour/38385-Custom-Field-Type-in-V3 but we are getting no suitable method found to override. We are inheriting the FieldType as described in the post.
    Are there any uptodate examples on how to create a TinyMCE FieldType for Contour?
    Many thanks
    Jon
    Jan 27, 2015 @ 09:22
    Jonathan Roberts
    Can I ask if this is at all possible?
    Jon
    Jan 27, 2015 @ 09:29
    Dennis Aaen
    Hi Jonanthan,
    Please don't double post - It creates too much noice and can lead to unwanted confusion :) http://our.umbraco.org/forum/umbraco-7/using-umbraco-7/60783-Create-TinyMCE-Editor-for-Contour-
    That being said, I assume that you are using Umbraco Forms, since you are using Umbraco 7.2. Try to see the documentation about how to extending the Umbraco Forms http://our.umbraco.org/documentation/Products/UmbracoForms/Developer/Extending/ and specific about field types: http://our.umbraco.org/documentation/Products/UmbracoForms/Developer/Extending/Adding-a-Fieldtype
    Hope this helps,
    /Dennis
    Jan 27, 2015 @ 09:37
    Jonathan Roberts
    Thanks for your reply and apologies for the Double Entry - its a bit confusing to where to place these questions.
    Regarding the post above, I have seen these types of posts before but cannot find one for the Tiny MCE. Do you know if there is anything available and why I am getting a no suitable method found to override?
    Jon
    Jan 27, 2015 @ 09:47
    Dennis Aaen
    Hi Jon,
    Can see Anthony are getting the same no suitable method found to override message like you in this thread http://our.umbraco.org/forum/umbraco-pro/contour/27135-country-picker-in-Contour. To it looks like the example is for Umbraco Forms. But I am not a backend developer :-)
    Perhaps you can solve it by reading through the thread above.
    Hope this helps,
    /Dennis
    Jan 27, 2015 @ 09:52
    Jonathan Roberts
    Thanks for your reply.
    I will wait for a back end developer to answer my question then as I have already read this article.
    Jon
    Jan 27, 2015 @ 15:01
    Jonathan Roberts
    This is the code that I am using
    using System;
    using System.Linq;
    using System.Web;
    using Umbraco.Forms.Core;
    using Umbraco.Forms.UI;
    using Umbraco.Forms.Core.Controls;
    using System.Web.UI.WebControls;
    using System.Web.UI; using umb = umbraco; using umbraco.editorControls;
    namespace CustomContour
    public class RichTextEditor_ContourFieldType : Umbraco.Forms.Core.FieldType
    [Umbraco.Forms.Core.Attributes.Setting("RichTextArea", description = "RichTextArea")] public string richTextArea { get; set; }
        private TextBox txt = new TextBox();
        public List<object> _value;
        public RichTextEditor_ContourFieldType()
            //Provider
            this.Id = new Guid("02CEC34E-502F-4ED7-9000-BA1A7FDFABD3");
            this.Name = "RichTextArea";
            this.Description = "Renders Content";
            this.Icon = "textfield.png";
            this.DataType = FieldDataType.String;
        public override WebControl Editor
            get
                if (_value.Count > 0)
                    txt.Text = _value[0].ToString();
                return txt;
            set { Editor = value; }
        public override List<Object> Values
            get
                if (txt.Text != "")
                    _value.Clear();
                    _value.Add(txt.Text);
                return _value;
            set { _value = value; }
        public override string RenderPreview()
            string o = string.Empty;
            o = @"<div class=""richTextArea"">" + richTextArea + "</div>";
            return o;
        public override string RenderPreviewWithPrevalues(List<object> prevalues)
            return RenderPreview();
  • Paul de Quant 403 posts 1521 karma points
    Jan 27, 2015 @ 16:40
    Paul de Quant
    Hi Jon,
    I've had a little look at this and I believe the reason why it's working for you is that your using an older version of Contour - I presume you're on the latest version (4 I think).
    Anyway I've managed to successfully create a Rich Text Editor for Contour.
    Firstly drop the overrides. They don't exist
    I've kept it basic for now:
    { public class RichTextEditor : Umbraco.Forms.Core.FieldType { [Umbraco.Forms.Core.Attributes.Setting("Rich Text Editor", description = "Rich Text Editor to allow users to submit formatted HTML")] public string richTextArea { get; set; } private TextBox txt = new TextBox(); public List
    Jan 27, 2015 @ 16:44
    Jonathan Roberts
    Amazing - many thanks for all your hard work - you are a life saver Thanks again, Jon
  • shailesh 2 posts 22 karma points
    Dec 28, 2017 @ 09:28
    shailesh
    Thanks for the nice post ,
    I tried the same things at my end and I am able to save data inside one table e.g employee but when i retrieve data then it's not able to get and set inside tinymce so can any one tell me what could not the problem
    here is my form.cshtml @using Umbraco.Forms.Core @using Umbraco.Forms.Mvc.Models @using Umbraco.Forms.Mvc.BusinessLogic @using Umbraco.Forms.MVC.Extensions @using Umbraco.Web @using ClientDependency.Core.Mvc;
    @model Umbraco.Forms.Mvc.Models.FormViewModel @{ Html.EnableClientValidation(true); Html.EnableUnobtrusiveJavaScript(true); }
    @if (Model.SubmitHandled) { if (Model.RenderMode == "full" || Model.RenderMode == "form") {
    @Html.Raw(Model.MessageOnSubmit)
    } } else { if (Model.RenderMode == "full" || Model.RenderMode == "form") {
         <div id="contour_form_@Model.FormClientId" class="contour @Model.CssClass">
             @using (Html.BeginUmbracoForm<Umbraco.Forms.Web.Controllers.UmbracoFormsController>("HandleForm"))
                 @Html.AntiForgeryToken()
                 <input type="hidden" name="FormId" value="@Model.FormId" />
                 @Html.HiddenFor(x => Model.FormName)
                 @Html.HiddenFor(x => Model.RecordId)
                 @Html.HiddenFor(x => Model.PreviousClicked)
                 <input type="hidden" name="FormStep" value="@Model.FormStep" />
                 <input type="hidden" name="RecordState" value="@Model.RecordState"/>
                 <div class="contourPage">
                     @if (string.IsNullOrEmpty(Model.CurrentPage.Caption) == false)
                         <h4 class="contourPageName">@Html.Raw(Model.CurrentPage.Caption)</h4>
                     @if (Model.ShowValidationSummary)
                         @Html.ValidationSummary(false)
                     @foreach (FieldsetViewModel fs in Model.CurrentPage.Fieldsets)
                        <fieldset class="contourFieldSet" id="@fs.Id">
                            @if (string.IsNullOrEmpty(fs.Caption) == false)
                                <legend>@Html.Raw(fs.Caption)</legend>
                            <div class="row-fluid">
                                @foreach (var c in fs.Containers)
                                    <div class="@("span" + c.Width) @("col-md-" + c.Width)">
                                        @foreach (FieldViewModel f in c.Fields)
                                            bool hidden = f.HasCondition && f.ConditionActionType == FieldConditionActionType.Show;
                                            <div class="@f.CssClass" @{ if (hidden) { <text> style="display: none" </text>  } }>
                                                @if (!f.HideLabel)
                                                    <label for="@f.Id" class="fieldLabel">
                                                        @Html.Raw(f.Caption) @if (f.ShowIndicator)
                                                            <span class="contourIndicator">@Model.Indicator</span>
                                                    </label>
                                                @if (!string.IsNullOrEmpty(f.ToolTip))
                                                    <span class="help-block">@f.ToolTip</span>
                                                <div>
                                                   @* <b>@Model.FormId.ToString()</b><br />
                                                    <b>@f.FieldType.FieldTypeViewName</b><br />
                                                    <b>@f.Caption</b><br />
                                                    <b>@f.Id</b>*@
                                                    @Html.Partial(FieldViewResolver.GetFieldView(Model.FormId.ToString(), f.FieldType.FieldTypeViewName, f.Caption), f)
                                                    @if (Model.ShowFieldValidaton)
                                                        @Html.ValidationMessage(f.Id)
                        </fieldset>
                     <div style="display: none">
                         <input type="text" name="@Model.FormId.ToString().Replace("-", "")" />
                     <div class="contourNavigation row-fluid">
                         <div class="col-md-12">
                             @if (Model.IsMultiPage)
                                 if (!Model.IsFirstPage)
                                     <input class="btn prev cancel" type="submit" value="@Model.PreviousCaption" name="__prev"/>
                                 if (!Model.IsLastPage)
                                     <input type="submit" class="btn next" value="@Model.NextCaption" name="next"/>
                                 if (Model.IsLastPage)
                                     <input type="submit" class="btn primary" value="@Model.SubmitCaption" name="submitbtn"/>
                             else
    if (Model.CurrentPage.PartialViewFiles.Any())
        foreach (var partial in Model.CurrentPage.PartialViewFiles)
            @Html.Partial(partial.Value)
    if (Model.RenderMode == "full" || Model.RenderMode == "script")
        @Html.Partial(FormViewResolver.GetScriptView(Model.FormId), Model)
        foreach (var script in Model.CurrentPage.JavascriptFiles)
            if (Model.UseClientDependency)
                Html.RequiresJs(script.Value);
            else
    <script type="text/javascript" src="@Url.Content(script.Value)"></script>
        if (Model.CurrentPage.JavascriptCommands.Count > 0)
                @foreach (var cmd in Model.CurrentPage.JavascriptCommands)
                    <text>@Html.Raw(cmd)</text>
            </script>
        foreach (var css in Model.CurrentPage.CssFiles)
                Html.RequiresCss(css.Value);
            else
                <link rel="stylesheet" href="@Url.Content(css.Value)" />
    And Inside Views\Partials\Forms\Fieldtypes\FieldType.RichTextEditor.cshtml file below is a code
    @model Umbraco.Forms.Mvc.Models.FieldViewModel
    <script type="text/javascript" src="@Url.Content("~/umbraco/lib/tinymce/tinymce.min.js")"></script>
    tinymce.init({
        selector: "textarea.rte",
        plugins: [
            "autolink autosave link image lists charmap preview hr anchor pagebreak spellchecker",
            "searchreplace wordcount visualblocks visualchars code fullscreen insertdatetime media nonbreaking",
            "table contextmenu directionality emoticons template textcolor paste textcolor"
        toolbar1: "bold italic | link unlink | formatselect",
        //toolbar2: "cut copy paste | searchreplace | bullist numlist | outdent indent blockquote | undo redo | link unlink anchor image media code | inserttime preview | forecolor backcolor",
        //toolbar3: "table | hr removeformat | subscript superscript | charmap emoticons | print fullscreen | ltr rtl | spellchecker | visualchars visualblocks nonbreaking template pagebreak restoredraft",
        remove_linebreaks: false,
        relative_urls: false,
        menubar: false,
        toolbar_items_size: 'small'
