  • Kris Scott 7 posts 47 karma points
    Jan 27, 2015 @ 00:46
    Kris Scott
    Does Member Tools work for Umbraco 7.2?
    I'm trying to use Contour Member Tools to create a member profile editor form in Umbraco 7.2, I've created the contour form, have the default values coming from {member.field}, which is working. I've set up a workflow for when the form is submitted to map form field values to member properties.
    When I attempt to change a value in the form from the front end as a logged in user, I see the default values, if I change a value and save it I see the form submitted message with no errors, but the changes are not saved. They are not visible in the backend, in the form if I reopen it, or in my 'hello, user' message on my home page if I change their name.
    Should Member Tools be working for Umbraco 7.2? If so is there some other action I need to take to enable the saves to work for Members?
