  • Maff 141 posts 466 karma points
    Jan 27, 2015 @ 11:20
    Maff
    Best way to get a Content Item in Contour Custom Workflow?
    I have added a Contour custom workflow step, and I'm getting a Content Item using the NodeFactory:
    var myEvent = new umbraco.NodeFactory.Node(eventId);
    This works fine, but I was just wondering if this is the best code to use, or if there is a better method?
    Maff
  • Sören Deger 733 posts 2844 karma points c-trib
    Jan 27, 2015 @ 11:32
    Sören Deger
    Hi Maff,
    you can use IPublishedContent for reading from cache:
    http://our.umbraco.org/documentation/Reference/Querying/UmbracoHelper/
    Or you can use ContentService for reading from Database:
    http://our.umbraco.org/documentation/Reference/Management-v6/Services/ContentService
    Best,
    Sören
    Jan 27, 2015 @ 11:38
    Maff
    Awesome - thanks Sören! Exactly what I was looking for :)
