  • Simon 692 posts 1068 karma points
    Jan 29, 2015 @ 10:07
    Simon
    Contour forms Required Sign
    Can anyone guide me how to set the asterix symbol next to the mandatory fields in the form pls?
    I am using Umbraco 7.
    thanks. Apprecaite any help!
    Regards
    Jan 29, 2015 @ 10:14
    Dennis Aaen
    Hi Simon,
    If you go to the settings of you form, then you can set the indicator that you want for mandatory fields.
    I have made a screenshot.
    Hope this helps,
    /Dennis
    Jan 29, 2015 @ 10:30
    Simon
    Hi Denis, once again,
    I have already tick that option but no fields has been marked with the asterix symbol, next to mandatory fields.
    I have checked that thos fields that are required has the option Mandatory ticked.
    Appreaciate any help.
    thank you.
    Regards
    Jan 29, 2015 @ 10:35
    Dennis Aaen
    Hi Simon,
    Could it be that you have missing to save the form, and after you update a field in your form, e.g check the mandatory field, then you also need to save the form, for it to take effect. It is not enough just to update the field. Same when you are change things in workflow and settings.
    Or did you get any javascript errors in your console.
    Hope this helps,
    /Dennis
    Jan 29, 2015 @ 10:41
    Simon
    Hi Dennis,
    I have already done that, to make sure.
    Do you have an idea, where the mandatory field is being generated from code?
    Regards
    Jan 29, 2015 @ 14:57
    Simon
    Ok Dennis
    Solved. I had some code commented in forms partial view cause I dont' want the labels to be displayed and eventually I commented also the indicator.
    Jan 29, 2015 @ 15:01
    Dennis Aaen
    Hi Simon.
    Ah okay, it can happen for all of us. But good to hear that you solved.
    /Dennis
    Jan 29, 2015 @ 15:07
    Simon
    Hi Dennis,
    Sry for bothering you again,
    Do you have an idea on this pls? - http://our.umbraco.org/forum/umbraco-pro/contour/60889-Get-emails-from-CMS-in-xslt-file-when-sending-to-different-emails
    thank you
    Regards
