  • Jonas 123 posts 206 karma points
    Feb 02, 2015 @ 13:33
    Jonas
    Installed forms not working.
    So, we installed the new forms and when trying to view a page that has a form macro on it renders...
    2015-02-02 13:31:48,553 [7] WARN umbraco.macro - [Thread 44] Error loading Partial View (file: ~/Views/MacroPartials/RenderFormsScript.cshtml). Exception: System.Web.HttpCompileException (0x80004005): d:\root\Views\MacroPartials\RenderFormsScript.cshtml(8): error CS1061: 'System.Web.Mvc.HtmlHelper
    Feb 02, 2015 @ 14:57
    Hi Jonas
    Did you make a clean install or did you upgrade from Contour?
    Feb 02, 2015 @ 14:58
    Jonas
    HI Jan, tried the clean approach.
    Feb 02, 2015 @ 15:05
    Hi Jonas
    I recall seeing Tim Geyssens write an answer to a post with a similar issue if I remember correctly but can't seem to find it. Don't know if it might be worth trying to install the nightlies to see if that helps?
