  • andrew shearer 513 posts 663 karma points
    Feb 03, 2015 @ 23:18
    andrew shearer
    issue when rendering contour form under ajax request
    Our site uses ajax to dynamically load in the next page of our site. In doing this it renders an RTE with a contour form macro. This produces the following exception:
    System.NullReferenceException: Object reference not set to an instance of an object. at Umbraco.Forms.Mvc.Controllers.FormRenderController.ContourForm() in f:\TeamCity\buildAgent\work\3b0e3c3a4846294b\Umbraco.Forms.Mvc\Controllers\FormRenderController.cs:line 39 at lambda_method(Closure , ControllerBase , Object[] ) at System.Web.Mvc.ActionMethodDispatcher.Execute(ControllerBase controller, Object[] parameters) at System.Web.Mvc.ReflectedActionDescriptor.Execute(ControllerContext controllerContext, IDictionary`2 parameters) at System.Web.Mvc.ControllerActionInvoker.InvokeActionMethod(ControllerContext controllerContext, ActionDescriptor\
    Is this an issue with this Contour Controller method not knowing the correct Umbraco context? Is this a known issue? Thanks
