  • Joel 7 posts 27 karma points
    Feb 13, 2015 @ 15:41
    Joel
    Formpicker could not be added in 7.1.6
    I've been trying to install Contour on Umbraco 7.1.6 but I always get the "Formpicker could not be added" error on install. I tried following the manual instructions. All the databases seem to be there. There already is a macro called "Insert form from Umbraco Contour" in the macros folder and in "Choose A File To Render" it has the Razor Script "MvcRenderContourForm.cshtml" selected. I did have to go to the parameters tab and add: Alias: FormGuid, Name: Choose a form, Type: Form picker. However after all that when I try to insert a form on a page through inserting a macro I get this:
    No dropdown to choose a form
    It just says "Choose a form" and there's the ghost of an outline of a dropdown box, but no actual dropdown. Due to the "Formpicker could not be added" error is there some other steps I need to do to get Contour all hooked up and running?
