How did you make the installation? Was it just by clicking the installation button when entering the form section or did you download the package and install it manually?
Perhaps you can see if any error messages exists in the /App_Data/Logs file?
I have the same issue today on 7.4.0. Fine locally but on remote server I have installed the package from the package repository as well as via the Install button and both completed without error but did NOT create the tables in the database. The database user is db_owner.
Nothing in the logs to indicate any problem whatsoever, even the umbracoLog table states
I had the same issue after installing Umbraco Forms through NuGet. It works on the local machine where I installed it but after uploading to the staging server I got the exception.
Solved my problem by upgrading Umbraco Forms on staging server.
Forms tables missing in db
installing the Forms Plugin in Umbraco 7.2.2. worked without any exceptions.
But the Forms Database schema is missing!
We get following message when we try to send a Form - "Invalid object name 'UFRecords'"
How can I create the db related stuff by hand?
The db user in our web.config connectionstring should have enough rights.
Regards, fabian
Hi Fabian
db_owner.Nothing in the logs to indicate any problem whatsoever, even the umbracoLog table states
The only way I could resolve this and force the table creation was to completely uninstall the package and install it again.
What version of Umbraco Forms are you using?
I did read in the 'Changes' section for 4.2.1 on the Umbraco Forms page that changes are made to the DB schema after an app restart but this only happens once: https://our.umbraco.org/projects/developer-tools/umbraco-forms/
For deployments to other servers, you'll need to create the 'marker' in /App_Data/TEMP/formsupdate
Hope this helps,
James.
