  • Paul 4 posts 75 karma points
    Mar 10, 2015 @ 11:12
    Paul
    Default value not being loaded
    Good Morning,
    I am fairly new to Umbraco so I'm still getting used to how it works, but I haven't had any real problems until now.
    I have created a code first form with properties such as
    [Field("", "",
    Caption = "Test",
    Type = typeof(Umbraco.Forms.Core.Providers.FieldTypes.Textfield),
    Mandatory = true,
    DefaultValue = "[#test]")]
    public string Test{ get; set; }
    In the development environment the property is loaded out correctly, but when I deploy the site to our staging environment the field is blank.
    I have checked the back office, the form is defined correctly with the default value in the additional settings area of the form. The document type includes a property with the alias "test" and the content defines a value for the property.
    I have deleted everything in App_Data, republished the entire site. Cleared the browser cache. Nothing seems to get that field to display the default value from the content section.
    Do anyone have an idea of what I might be missing?
    Kind Regards,
    Paul
    Mar 10, 2015 @ 15:00
    Paul
    I have worked this one out, in umbracoSettings.config I have distributedCall="true" with a single server in the servers section to get scheduled publishing working because without it I get strange requests for port 443 over http but thats another issue.
    Simply settings distributedCall="false" and the default value in the form loads correctly.
