  • Andy Boston 28 posts 47 karma points
    Mar 10, 2015 @ 13:35
    Andy Boston
    Contour not saving settings
    I'm making changes to the form settings but they're not being saved to the system.
    For instance. I set a form to go to a thank you page after submit , I click OK and it looks like it's done but when i go back it's reverted back to default
    Does anyone have any ideas? Is it a "write" setting somewhere?
    Mar 10, 2015 @ 13:42
    Hi Andy
    What version of Umbraco are you using and what version of Contour/Umbraco Forms? I think there might is a known issue about this in forms.
    Mar 10, 2015 @ 13:48
    Hi Andy
    Can't seem to find any reported issue about it but try looking through the issues here http://issues.umbraco.org/issues?q=project%3A+%7BUmbraco+Forms+%28aka+Contour%29%7D - If it's not found then it might be a good idea to add it.
    Mar 10, 2015 @ 15:52
    Andy Boston
    <blush> my bad
    it helps if you click the "Save" button rather than just "OK" after changing the settings
    Mar 10, 2015 @ 15:55
    Hi Andy
    Aaah, well yeah indeed that helps :)
