Following my previous post, I set up my Contour licence (umbracoForms.lic) and copied it to my website /BIN directory.
Now, I get an error when accessing the Contour tab in Umbraco and I couldn't get a relevant answer in the forum :
Errordetail: System.Resources.MissingManifestResourceException:
Could not find any resources appropriate for the specified culture or
the neutral culture. Make sure
"Infralution.Licensing.LicenseResources.resources" was correctly
embedded or linked into assembly "Umbraco.Forms.Licensing" at compile
time, or that all the satellite assemblies required are loadable and
fully signed.
System.Resources.ResourceManager.InternalGetResourceSet(CultureInfo culture, Boolean createIfNotExists, Boolean tryParents) +7678206 System.Resources.ResourceManager.InternalGetResourceSet(CultureInfo culture, Boolean createIfNotExists, Boolean tryParents) +583 System.Resources.ResourceManager.InternalGetResourceSet(CultureInfo culture, Boolean createIfNotExists, Boolean tryParents) +583 System.Resources.ResourceManager.GetString(String name, CultureInfo culture) +74 Infralution.Licensing.LicenseResources.get_ReadErrorMsg() in d:\TeamCity\buildAgent\work\39da791f9304089a\Umbraco.Forms.Licensing\Infraluation\LicenseResources.Designer.cs:292 Infralution.Licensing.EncryptedLicenseProvider.ReadKeyFromFile(String licenseFile) in d:\TeamCity\buildAgent\work\39da791f9304089a\Umbraco.Forms.Licensing\Infraluation\EncryptedLicenseProvider.cs:1091 Infralution.Licensing.EncryptedLicenseProvider.GetLicense(String licenseFile) in d:\TeamCity\buildAgent\work\39da791f9304089a\Umbraco.Forms.Licensing\Infraluation\EncryptedLicenseProvider.cs:619 Infralution.Licensing.EncryptedLicenseProvider.GetLicense(String licenseParameters, String licenseFile) in d:\TeamCity\buildAgent\work\39da791f9304089a\Umbraco.Forms.Licensing\Infraluation\EncryptedLicenseProvider.cs:644 Umbraco.Forms.Licensing.Validate.GetLicense() in d:\TeamCity\buildAgent\work\39da791f9304089a\Umbraco.Forms.Licensing\Validate.cs:162 Umbraco.Forms.Licensing.Validate.ValidateLicense() in d:\TeamCity\buildAgent\work\39da791f9304089a\Umbraco.Forms.Licensing\Validate.cs:80 Umbraco.Forms.Licensing.Validate.IsTrial() in d:\TeamCity\buildAgent\work\39da791f9304089a\Umbraco.Forms.Licensing\Validate.cs:47 Umbraco.Forms.Core.Configuration.get_IsTrial() in d:\TeamCity\buildAgent\work\39da791f9304089a\Umbraco.Forms.Core\Configuration.cs:30 Umbraco.Forms.UI.Dashboard.FormsDashboard.Page_Load(Object sender, EventArgs e) in d:\TeamCity\buildAgent\work\39da791f9304089a\Umbraco.Forms.UI\Dashboard\FormsDashboard.ascx.cs:34 System.Web.Util.CalliHelper.EventArgFunctionCaller(IntPtr fp, Object o, Object t, EventArgs e) +14 System.Web.Util.CalliEventHandlerDelegateProxy.Callback(Object sender, EventArgs e) +35 System.Web.UI.Control.OnLoad(EventArgs e) +99 System.Web.UI.Control.LoadRecursive() +50 System.Web.UI.Control.LoadRecursive() +141 System.Web.UI.Control.LoadRecursive() +141 System.Web.UI.Control.LoadRecursive() +141 System.Web.UI.Control.LoadRecursive() +141 System.Web.UI.Control.LoadRecursive() +141 System.Web.UI.Control.LoadRecursive() +141 System.Web.UI.Page.ProcessRequestMain(Boolean includeStagesBeforeAsyncPoint, Boolean includeStagesAfterAsyncPoint) +627
I removed my umbracoForms.lic file from /BIN, and went back to trial mode only to notice the Contour automatic licence installation form.
I entered my credentials, it downloaded the licence and now it works. The downloaded umbracoForms.lic file has been added to the /BIN directory.
Nice to see that it is automagical, but I would like to know what difference there was between those two ways of setting up a Contour licence. None visible as far as I know.
Looks like the Contour automatic licence installation form allows for the file to have substantial extra security users and access rights on Win server 2003. Namely :
Contour licence installation
Error detail: System.Resources.MissingManifestResourceException: Could not find any resources appropriate for the specified culture or the neutral culture. Make sure "Infralution.Licensing.LicenseResources.resources" was correctly embedded or linked into assembly "Umbraco.Forms.Licensing" at compile time, or that all the satellite assemblies required are loadable and fully signed.
<appSettings>
<add key="umbracoDbDSN" value="" />
<add key="umbracoConfigurationStatus" value="4.0.2.1" />
<add key="umbracoReservedUrls" value="/config/splashes/booting.aspx,/install/default.aspx,/config/splashes/noNodes.aspx" />
<add key="umbracoReservedPaths" value="/umbraco/" />
<add key="umbracoContentXML" value="/data/umbraco.config" />
<add key="umbracoStorageDirectory" value="/data" />
<add key="umbracoPath" value="/umbraco" />
<add key="umbracoEnableStat" value="false" />
<add key="umbracoHideTopLevelNodeFromPath" value="true" />
<add key="umbracoEditXhtmlMode" value="true" />
<add key="umbracoUseDirectoryUrls" value="false" />
<add key="umbracoDebugMode" value="true" />
<add key="umbracoTimeOutInMinutes" value="20" />
<add key="umbracoDisableVersionCheck" value="true" />
<add key="umbracoDisableXsltExtensions" value="true" />
<add key="umbracoDefaultUILanguage" value="en" />
<add key="umbracoProfileUrl" value="profiler" />
<add key="umbracoUseSSL" value="false" />
<add key="umbracoUseMediumTrust" value="false" />
</appSettings>
Regards,
Lauris Stephani
Regards,
Lauris Stephani
