Thanks to Tim I found the config file for creating more "templates", but is there any documentation tied to how one goes about creating those templates? Or better yet a way to create a form in the gui interface and then pull "the guts" of it into XML?
I have a drop down with pre-populated values.........all the US states, not something I want to have to enter over again.
I tried added a prevalue data source and got all the way to "Create Form" and using the drop down option, it fails and returns the following error. I'm thinking this is a bug.
Server Error in '/' Application. Object reference not set to an instance of an object. Description: An unhandled exception occurred during the execution of the current web request. Please review the stack trace for more information about the error and where it originated in the code.
Source Error:
Line 221: update</a> <a class="iconButton delete" href="#" onclick="javascript:DeleteField('<%# ((Umbraco.Forms.Core.Field)Container.DataItem).Id %>');"> Line 222: delete</a> <span class="handle">handle</span> Line 223: <div class="fieldprevalues" style="display: none;" <%# GetPrevalueAttributes(((Umbraco.Forms.Core.Field)Container.DataItem)) %>> Line 224: <asp:Repeater ID="rptPrevalues" runat="server"> Line 225: <ItemTemplate>
templating
Comment author was deleted
Hi Dan,
You could create a prevalue source (with all states) that you can reuse on all your forms.
Tim,
Source Error:
Source File: d:\webtemplates\umbraco\usercontrols\umbracoContour\EditForm.ascx Line: 223
Stack Trace:
Umbraco.Forms.UI.Usercontrols.EditForm.GetPrevalueAttributes(Field f) in d:\TeamCity\buildAgent\work\39da791f9304089a\Umbraco.Forms.UI\Usercontrols\EditForm.ascx.cs:179
ASP.usercontrols_umbracocontour_editform_ascx.__DataBind__control9(Object sender, EventArgs e) in d:\webtemplates\umbraco\usercontrols\umbracoContour\EditForm.ascx:223
System.Web.UI.Control.OnDataBinding(EventArgs e) +99
System.Web.UI.Control.DataBind(Boolean raiseOnDataBinding) +92
System.Web.UI.Control.DataBind() +15
System.Web.UI.Control.DataBindChildren() +211
System.Web.UI.Control.DataBind(Boolean raiseOnDataBinding) +102
System.Web.UI.WebControls.Repeater.CreateItem(Int32 itemIndex, ListItemType itemType, Boolean dataBind, Object dataItem) +124
System.Web.UI.WebControls.Repeater.CreateControlHierarchy(Boolean useDataSource) +443
System.Web.UI.WebControls.Repeater.OnDataBinding(EventArgs e) +51
System.Web.UI.WebControls.Repeater.DataBind() +75
Umbraco.Forms.UI.Usercontrols.EditForm.RenderFieldset(Object sender, RepeaterItemEventArgs e) in d:\TeamCity\buildAgent\work\39da791f9304089a\Umbraco.Forms.UI\Usercontrols\EditForm.ascx.cs:114
System.Web.UI.WebControls.Repeater.OnItemDataBound(RepeaterItemEventArgs e) +108
System.Web.UI.WebControls.Repeater.CreateItem(Int32 itemIndex, ListItemType itemType, Boolean dataBind, Object dataItem) +136
Umbraco.Forms.UI.Usercontrols.EditForm.RenderPage(Object sender, RepeaterItemEventArgs e) in d:\TeamCity\buildAgent\work\39da791f9304089a\Umbraco.Forms.UI\Usercontrols\EditForm.ascx.cs:102
Umbraco.Forms.UI.Usercontrols.EditForm.Page_Load(Object sender, EventArgs e) in d:\TeamCity\buildAgent\work\39da791f9304089a\Umbraco.Forms.UI\Usercontrols\EditForm.ascx.cs:59
System.Web.Util.CalliHelper.EventArgFunctionCaller(IntPtr fp, Object o, Object t, EventArgs e) +14
System.Web.Util.CalliEventHandlerDelegateProxy.Callback(Object sender, EventArgs e) +35
System.Web.UI.Control.OnLoad(EventArgs e) +99
System.Web.UI.Control.LoadRecursive() +50
System.Web.UI.Control.LoadRecursive() +141
System.Web.UI.Page.ProcessRequestMain(Boolean includeStagesBeforeAsyncPoint, Boolean includeStagesAfterAsyncPoint) +627
Version Information: Microsoft .NET Framework Version:2.0.50727.3082; ASP.NET Version:2.0.50727.3082
I forgot to say the error line it points to is
