    Mar 23, 2015 @ 16:23
    Ismail Mayat
    Prevalues in contour 3.0.6
    Guys.
    Using umbraco 4.7.0 and contour 3.0.6
    When using prevalues and source as umbraco documents we get in forms the node id and not text of the node, was it in contour >3.0.6 that this was updated so you got text of node.  I recall with really old versions of umbraco you had to implement post processing with workflow.
    Regards
    Ismail
  • Comment author was deleted
    Mar 23, 2015 @ 16:25
    Yeah since you are using a pretty old version... in your workflow you can check if it's an int if it is then do additional processing... (fetching the value from the id)
    Mar 23, 2015 @ 16:28
    Ismail Mayat
    Tim,
    With 4.7.0 what version of contour can i upgrade to so i get text instead?
    Regards
    Ismail
    Mar 23, 2015 @ 16:32
    Hmm can't see it in the changes doc  http://nightly.umbraco.org/Umbraco%20Contour/changes.txt but 3.0.6 is the max you can get on 4.7.0
    But you can of course just create a custom prevalue sourcetype and deploy that if upgrading isn't an option (just just be copy paste with a little update if you start from the shared sourcecode)
    Mar 23, 2015 @ 16:34
    Ismail Mayat
    Tim,
    No worries I will do that I already have some code knocking around somewhere was looking for the easy option of doing upgrade!!!
    Cheers
    Ismail
