I noticed that the Umbraco Forms tables were not created. I assume it is a DB user permission user like the issue I found in this old post about Contour:
Exception information:
Exception type: SqlException
Exception message: Invalid object name 'UFRecords'.
at System.Data.SqlClient.SqlConnection.OnError(SqlException exception, Boolean breakConnection, Action1 wrapCloseInAction)
at System.Data.SqlClient.TdsParser.ThrowExceptionAndWarning(TdsParserStateObject stateObj, Boolean callerHasConnectionLock, Boolean asyncClose)
at System.Data.SqlClient.TdsParser.TryRun(RunBehavior runBehavior, SqlCommand cmdHandler, SqlDataReader dataStream, BulkCopySimpleResultSet bulkCopyHandler, TdsParserStateObject stateObj, Boolean& dataReady)
at System.Data.SqlClient.SqlDataReader.TryConsumeMetaData()
at System.Data.SqlClient.SqlDataReader.get_MetaData()
at System.Data.SqlClient.SqlCommand.FinishExecuteReader(SqlDataReader ds, RunBehavior runBehavior, String resetOptionsString)
at System.Data.SqlClient.SqlCommand.RunExecuteReaderTds(CommandBehavior cmdBehavior, RunBehavior runBehavior, Boolean returnStream, Boolean async, Int32 timeout, Task& task, Boolean asyncWrite, SqlDataReader ds)
at System.Data.SqlClient.SqlCommand.RunExecuteReader(CommandBehavior cmdBehavior, RunBehavior runBehavior, Boolean returnStream, String method, TaskCompletionSource1 completion, Int32 timeout, Task& task, Boolean asyncWrite)
at System.Data.SqlClient.SqlCommand.RunExecuteReader(CommandBehavior cmdBehavior, RunBehavior runBehavior, Boolean returnStream, String method)
at System.Data.SqlClient.SqlCommand.ExecuteScalar()
at StackExchange.Profiling.Data.ProfiledDbCommand.ExecuteScalar()
at Umbraco.Core.Persistence.PetaPocoCommandExtensions.<>cDisplayClassa.9()
at Umbraco.Core.Persistence.FaultHandling.RetryPolicy.ExecuteAction[TResult](Func1 func)
at Umbraco.Core.Persistence.Database.Insert(String tableName, String primaryKeyName, Boolean autoIncrement, Object poco)
at Umbraco.Core.Persistence.Database.Insert(Object poco)
at Umbraco.Forms.Data.Storage.RecordStorage.InsertRecord(Record record, Form form)
at Umbraco.Forms.Web.Services.RecordService.storeRecord(Record record, Form form) in f:\TeamCity\buildAgent\work\133677a4e37ceece\Umbraco.Forms.Mvc\Services\RecordService.cs:line 29
at Umbraco.Forms.Web.Services.RecordService.Approve(Record record, Form form) in f:\TeamCity\buildAgent\work\133677a4e37ceece\Umbraco.Forms.Mvc\Services\RecordService.cs:line 107
at Umbraco.Forms.Web.Services.RecordService.Submit(Record record, Form form) in f:\TeamCity\buildAgent\work\133677a4e37ceece\Umbraco.Forms.Mvc\Services\RecordService.cs:line 93
at Umbraco.Forms.Web.Controllers.UmbracoFormsController.SubmitForm(Form form, FormViewModel model, Dictionary2 state, ControllerContext context) in f:\TeamCity\buildAgent\work\133677a4e37ceece\Umbraco.Forms.Mvc\Controllers\UmbracoFormsController.cs:line 215
at Umbraco.Forms.Web.Controllers.UmbracoFormsController.GoForward(Form form, FormViewModel model, Dictionary2 state) in f:\TeamCity\buildAgent\work\133677a4e37ceece\Umbraco.Forms.Mvc\Controllers\UmbracoFormsController.cs:line 161
at Umbraco.Forms.Web.Controllers.UmbracoFormsController.HandleForm(FormViewModel model, Boolean captchaIsValid) in f:\TeamCity\buildAgent\work\133677a4e37ceece\Umbraco.Forms.Mvc\Controllers\UmbracoFormsController.cs:line 114
at lambda_method(Closure , ControllerBase , Object[] )
at System.Web.Mvc.ReflectedActionDescriptor.Execute(ControllerContext controllerContext, IDictionary2 parameters)
at System.Web.Mvc.ControllerActionInvoker.InvokeActionMethod(ControllerContext controllerContext, ActionDescriptor actionDescriptor, IDictionary`2 parameters)
at System.Web.Mvc.Async.AsyncControllerActionInvoker.<>cDisplayClass37.<>cDisplayClass39.
It took a long time to figure this out since there was no error message in the Back Office when I installed Umbraco Forms. In fact, I was able to register the license and start building forms and didn't discover this until I went to export form data. So I think that Umbraco Forms should be improved so that the installer warns users when it can't create the tables.
Now that I'm in this state, I'd like to just create the tables (and any other DB objects needed. Are their SQL Scripts available somewhere for this?
Umbraco Forms tables not installed
https://our.umbraco.org/forum/umbraco-pro/contour/26385-Contour-installation-error
This is what was in the umbraco log:
Exception information: Exception type: SqlException Exception message: Invalid object name 'UFRecords'. at System.Data.SqlClient.SqlConnection.OnError(SqlException exception, Boolean breakConnection, Action
1 wrapCloseInAction) at System.Data.SqlClient.TdsParser.ThrowExceptionAndWarning(TdsParserStateObject stateObj, Boolean callerHasConnectionLock, Boolean asyncClose) at System.Data.SqlClient.TdsParser.TryRun(RunBehavior runBehavior, SqlCommand cmdHandler, SqlDataReader dataStream, BulkCopySimpleResultSet bulkCopyHandler, TdsParserStateObject stateObj, Boolean& dataReady) at System.Data.SqlClient.SqlDataReader.TryConsumeMetaData() at System.Data.SqlClient.SqlDataReader.get_MetaData() at System.Data.SqlClient.SqlCommand.FinishExecuteReader(SqlDataReader ds, RunBehavior runBehavior, String resetOptionsString) at System.Data.SqlClient.SqlCommand.RunExecuteReaderTds(CommandBehavior cmdBehavior, RunBehavior runBehavior, Boolean returnStream, Boolean async, Int32 timeout, Task& task, Boolean asyncWrite, SqlDataReader ds) at System.Data.SqlClient.SqlCommand.RunExecuteReader(CommandBehavior cmdBehavior, RunBehavior runBehavior, Boolean returnStream, String method, TaskCompletionSource1 completion, Int32 timeout, Task& task, Boolean asyncWrite) at System.Data.SqlClient.SqlCommand.RunExecuteReader(CommandBehavior cmdBehavior, RunBehavior runBehavior, Boolean returnStream, String method) at System.Data.SqlClient.SqlCommand.ExecuteScalar() at StackExchange.Profiling.Data.ProfiledDbCommand.ExecuteScalar() at Umbraco.Core.Persistence.PetaPocoCommandExtensions.<>cDisplayClassa.9() at Umbraco.Core.Persistence.FaultHandling.RetryPolicy.ExecuteAction[TResult](Func1 func) at Umbraco.Core.Persistence.Database.Insert(String tableName, String primaryKeyName, Boolean autoIncrement, Object poco) at Umbraco.Core.Persistence.Database.Insert(Object poco) at Umbraco.Forms.Data.Storage.RecordStorage.InsertRecord(Record record, Form form) at Umbraco.Forms.Web.Services.RecordService.storeRecord(Record record, Form form) in f:\TeamCity\buildAgent\work\133677a4e37ceece\Umbraco.Forms.Mvc\Services\RecordService.cs:line 29 at Umbraco.Forms.Web.Services.RecordService.Approve(Record record, Form form) in f:\TeamCity\buildAgent\work\133677a4e37ceece\Umbraco.Forms.Mvc\Services\RecordService.cs:line 107 at Umbraco.Forms.Web.Services.RecordService.Submit(Record record, Form form) in f:\TeamCity\buildAgent\work\133677a4e37ceece\Umbraco.Forms.Mvc\Services\RecordService.cs:line 93 at Umbraco.Forms.Web.Controllers.UmbracoFormsController.SubmitForm(Form form, FormViewModel model, Dictionary2 state, ControllerContext context) in f:\TeamCity\buildAgent\work\133677a4e37ceece\Umbraco.Forms.Mvc\Controllers\UmbracoFormsController.cs:line 215 at Umbraco.Forms.Web.Controllers.UmbracoFormsController.GoForward(Form form, FormViewModel model, Dictionary2 state) in f:\TeamCity\buildAgent\work\133677a4e37ceece\Umbraco.Forms.Mvc\Controllers\UmbracoFormsController.cs:line 161 at Umbraco.Forms.Web.Controllers.UmbracoFormsController.HandleForm(FormViewModel model, Boolean captchaIsValid) in f:\TeamCity\buildAgent\work\133677a4e37ceece\Umbraco.Forms.Mvc\Controllers\UmbracoFormsController.cs:line 114 at lambda_method(Closure , ControllerBase , Object[] ) at System.Web.Mvc.ReflectedActionDescriptor.Execute(ControllerContext controllerContext, IDictionary2 parameters) at System.Web.Mvc.ControllerActionInvoker.InvokeActionMethod(ControllerContext controllerContext, ActionDescriptor actionDescriptor, IDictionary`2 parameters) at System.Web.Mvc.Async.AsyncControllerActionInvoker.<>cDisplayClass37.<>cDisplayClass39.It took a long time to figure this out since there was no error message in the Back Office when I installed Umbraco Forms. In fact, I was able to register the license and start building forms and didn't discover this until I went to export form data. So I think that Umbraco Forms should be improved so that the installer warns users when it can't create the tables.
Alex
