  • Michael 125 posts 409 karma points
    Mar 26, 2015 @ 07:46
    Michael
    Error loading MacroEngine script
    I've noticed a lot of errors
    Error loading MacroEngine script (file: MvcRenderContourForm.cshtml, Type: ''. Exception: System.Web.HttpException (0x80004005): Server cannot modify cookies after HTTP headers have been sent. at System.Web.HttpCookieCollection.Set(HttpCookie cookie) at System.Web.Helpers.AntiXsrf.AntiForgeryWorker.GetFormInputElement(HttpContextBase httpContext) at System.Web.Helpers.AntiForgery.GetHtml() at System.Web.Mvc.HtmlHelper.AntiForgeryToken() at ASP._Page_umbraco_plugins_umbracoContour_Views_Form_cshtml.Execute() in \umbraco\Plugins\umbracoContour\Views\Form.cshtml:line 50 at System.Web.WebPages.WebPageBase.ExecutePageHierarchy() at System.Web.Mvc.WebViewPage.ExecutePageHierarchy() at System.Web.WebPages.WebPageBase.ExecutePageHierarchy(WebPageContext pageContext, TextWriter writer, WebPageRenderingBase startPage) at Umbraco.Core.Profiling.ProfilingView.Render(ViewContext viewContext, TextWriter writer) at System.Web.Mvc.ViewResultBase.ExecuteResult(ControllerContext context) at System.Web.Mvc.ControllerActionInvoker.<>c__DisplayClass1a.<InvokeActionResultWithFilters>b__17() at System.Web.Mvc.ControllerActionInvoker.InvokeActionResultFilter(IResultFilter filter, ResultExecutingContext preContext, Func`1 continuation) at System.Web.Mvc.ControllerActionInvoker.InvokeActionResultFilter(IResultFilter filter, ResultExecutingContext preContext, Func`1 continuation) at System.Web.Mvc.ControllerActionInvoker.InvokeActionResultFilter(IResultFilter filter, ResultExecutingContext preContext, Func`1 continuation) at System.Web.Mvc.ControllerActionInvoker.InvokeActionResultFilter(IResultFilter filter, ResultExecutingContext preContext, Func`1 continuation) at System.Web.Mvc.ControllerActionInvoker.InvokeActionResultFilter(IResultFilter filter, ResultExecutingContext preContext, Func`1 continuation) at System.Web.Mvc.ControllerActionInvoker.InvokeActionResultWithFilters(ControllerContext controllerContext, IList`1 filters, ActionResult actionResult) at System.Web.Mvc.ControllerActionInvoker.InvokeAction(ControllerContext controllerContext, String actionName) at System.Web.Mvc.Controller.ExecuteCore() at System.Web.Mvc.ControllerBase.Execute(RequestContext requestContext) at Umbraco.Forms.Mvc.Bridge.Html.MvcBridgeExtensions.RenderMvcAction(HtmlHelper helper, String action, String controller, String formId, String antiForgeryToken, Object node, Object parameter) in \TeamCity\buildAgent\work\fd622d7f786e1305\Umbraco.Forms.Mvc\Bridge\Html\MvcBridgeExtensions.cs:line 84 at ASP._Page_macroScripts_MvcRenderContourForm_cshtml.Execute() in \macroScripts\MvcRenderContourForm.cshtml:line 9 at System.Web.WebPages.WebPageBase.ExecutePageHierarchy() at System.Web.WebPages.WebPage.ExecutePageHierarchy() at System.Web.WebPages.WebPageBase.ExecutePageHierarchy(WebPageContext pageContext, TextWriter writer, WebPageRenderingBase startPage) at umbraco.MacroEngines.RazorMacroEngine.ExecuteRazor(MacroModel macro, INode currentPage) at umbraco.MacroEngines.RazorMacroEngine.Execute(MacroModel macro, INode currentPage) at umbraco.macro.loadMacroScript(MacroModel macro) at umbraco.macro.renderMacro(Hashtable pageElements, Int32 pageId)
    Mar 26, 2015 @ 07:59
    Hi Michael
    Could you tell us more about the issue? Like what version of Umbraco are you using? What version of COntour/Forms are you using? When does this happen?
    Cheers, Jan
    Mar 27, 2015 @ 15:22
    Michael
    Hi Jan,
    Umbraco version 7.1.4
    Contour version 3.0.24-Build.31
    It happen sometimes, I can't reproduce this bug locally.
    Michael
    Mar 27, 2015 @ 16:53
    Hi Michael
    What is your proces going from local to production? Seems like you're using TeamCity? Could you perhaps be missing some files? or could it be that some id's exists locally and not in production if you rely on hardcoded id's for some reason?
  • allywatson 5 posts 25 karma points
    Apr 22, 2015 @ 03:18
    allywatson
    Hi Michael,
    I also have this issue (not with contour but with UmbracoForms)! I am only getting the error in my logs but it is happening a lot! and only on the production environment.
    After a little googling I saw that someone else thought it could be an issue with the AntiForgeryToken and crawlers? But they couldn't confirm this. http://orchard.codeplex.com/workitem/20847
    I have not been able to reproduce locally either.
    I am using Umbraco v6.1.6.
    My view is as follows:-
    @model Project.Models.ViewModels.EmailSignupViewModel
    @using (Html.BeginUmbracoForm("Submit", "EmailSignup", new { @class = "subscribe" }))
        @Html.AntiForgeryToken()
        @Html.TextBoxFor(Model => Model.EmailAddress, new { @class = "email", @placeholder = "Email address", @type = "email", @required = "required" })
        <button class="submit">Subscribe</button>
    My controller:-
    public class EmailSignupController : SurfaceController
        [ValidateAntiForgeryToken]
        [HttpPost]
        public ActionResult Submit(EmailSignupViewModel model)
            if (!ModelState.IsValid)
                return
                    Json(
                        new {
                            Success = false,
                            Message = "There was an error submitting the form, please try again later."
            // add email address to database
            DbService dbService = new DbService();
            dbService.InsertEmailSubscription(model.EmailAddress);
            return Json(new { Success = true });
    And my stacktrace:-
       at ASP._Page_Views_Partials_SubscribeForm_cshtml.Execute() in \\172.22.19.156\content1\svc002\Views\Partials\SubscribeForm.cshtml:line 5
       at StackExchange.Profiling.MVCHelpers.WrappedView.Render(ViewContext viewContext, TextWriter writer)
       at System.Web.Mvc.Html.PartialExtensions.Partial(HtmlHelper htmlHelper, String partialViewName, Object model, ViewDataDictionary viewData)
       at ASP._Page_Views_Partials_Subscribe_cshtml.Execute() in \\172.22.19.156\content1\svc002\Views\Partials\Subscribe.cshtml:line 5
       at ASP._Page_Views_Partials_PageHead_cshtml.Execute() in \\172.22.19.156\content1\svc002\Views\Partials\PageHead.cshtml:line 27
       at ASP._Page_Views_Master_cshtml.Execute() in \\172.22.19.156\content1\svc002\Views\Master.cshtml:line 50
       at System.Web.WebPages.WebPageBase.Write(HelperResult result)
       at System.Web.WebPages.WebPageBase.RenderSurrounding(String partialViewName, Action`1 body)
       at System.Web.WebPages.WebPageBase.PopContext()
       at System.Web.Mvc.Controller.<>c__DisplayClass1d.<BeginExecuteCore>b__19()
       at System.Web.Mvc.Async.AsyncResultWrapper.<>c__DisplayClass1.<MakeVoidDelegate>b__0()
       at System.Web.Mvc.Controller.EndExecuteCore(IAsyncResult asyncResult)
       at System.Web.Mvc.Async.AsyncResultWrapper.<>c__DisplayClass4.<MakeVoidDelegate>b__3(IAsyncResult ar)
       at System.Web.Mvc.Controller.EndExecute(IAsyncResult asyncResult)
       at System.Web.Mvc.MvcHandler.<>c__DisplayClass8.<BeginProcessRequest>b__3(IAsyncResult asyncResult)
       at System.Web.Mvc.MvcHandler.EndProcessRequest(IAsyncResult asyncResult)
       at System.Web.HttpApplication.CallHandlerExecutionStep.System.Web.HttpApplication.IExecutionStep.Execute()
       at System.Web.HttpApplication.ExecuteStep(IExecutionStep step, Boolean& completedSynchronously)
    Apr 23, 2015 @ 12:54
    Michael
    Hi All,
    I have this problemon both (local, prod)
    But this problem occurs sometimes, and if this error happen form just reload page and no workflow was executed.
  • Tajamal 87 posts 175 karma points
    Nov 14, 2017 @ 12:19
    Tajamal
    anyone found a solution on this ?
