  • Nicolai Winch Kristensen 50 posts 70 karma points
    Apr 01, 2015 @ 20:05
    Contour Entries not showing..
    My Entries is in the UFRecords table in DB. But the do not show in Umbraco/Contour backend.
    Heres what happened: I took a backup of the solutions files, created a new website in IIS and connected to the same DB as before. seemes to work except the entries in Contour. tey are not showing in backend.
    Is there some files (indexes) that I need to copy as well and if so  where its stored?
    or is ther another reason for this?
    :-) Nicolai
    Apr 01, 2015 @ 20:15
    Hi Nicolai
    What version of Umbraco are you using? And what version of Contour?
    Have you tried checking the /App_Data/Logs fil to see if it reveals any details related to the issue?
    Have you double checked permissions on the new instance you have setup?
    Apr 01, 2015 @ 20:57
    Hi Jan - thx for fast response :-)
    of course relevant info: Umbraco v6.1.5 (Assembly version: 1.0.4993.19246 -  the contour package says: Package version 3.0.16
    Cannot find anything in the logs.
    With Permission I guess you mean for the NETWORK SERVICE?
    Extra info: I filled out a form. and the new entries becomes visible, but not the entries before the copy.
    :-) Nicolai
  • Comment author was deleted
    Apr 02, 2015 @ 10:33
    @Nicolai it should just work :) if the new entries appear then everything is setup correctly. Make sure the filter isn't to only showing the latest 24 hours
    Apr 02, 2015 @ 12:06
    Well, that it. Only 24 hours... stupid stupid me - the "switch" wasnt turned on. Sorry for disturbing all of you. And thank you so much ;-)
    Apr 02, 2015 @ 12:39
    Thought so, glad it's solved :)
