  • stefano 6 posts 26 karma points
    Apr 15, 2015 @ 16:13
    stefano
    Forms entries order created column not fire
    Hi everyone,
    I have istalled contour on an Umbraco 7 instance, when i select contour/forms/entries and select decade i view a table with all the results sorted by creation date descending.
    If I select the column created, the system tells me "processing..." but the results remain the same sort.
    Can anyone help me?
    Thanks in advance
    Stefano
  • Comment author was deleted
    Apr 15, 2015 @ 16:16
    Does the processing notification go away eventually or does it seem to hang?
    Apr 15, 2015 @ 16:18
    stefano
    the notification go away.
    Apr 15, 2015 @ 16:22
    Ok I can confirm the behaviour, it's a bug and will be fixed in the next maintenance release, you can expect an update here later this week.
    Apr 15, 2015 @ 16:24
    stefano
    Thanks a lot
    Stefano
    May 08, 2015 @ 15:03
    stefano
    Hi Tim,
    i've upgraded the package (Umbraco Contour version 3.0.27), but still not working.
    The notification go away but records are not ordered
    Regards
    Stefano
    May 08, 2015 @ 15:47
    Ok thanks for the details will take an additional look
