  • Lachlann 344 posts 626 karma points
    Apr 15, 2015 @ 16:28
    Lachlann
    Form Picker as Dropdown not Radio Checkboxes, Umbraco 7.2 Forms
    Hi All,
    I have been asking a bunch of questions today so thought I would ask then answer my own.
    By default the Form Picker for Umbraco Forms is a radio button list with a clear link (to clear a selection). The client I am working for is likley to have a very large list of forms so we thought it would be better if the control was displayed as a select drop down.
    Apr 15, 2015 @ 16:30
    Lachlann
    102
    to change this you need to find the formpicker.html view in: App_Plugins/UmbracoForms/Backoffice/PropertyEditors
    Then change the radio list to:
         <select  ng-model="model.value" ng-options="form.id as form.name for form in forms">
            <option selected value="">Select a form</option>
         </select>
    Hopefully this helps some one out :)
    L
