  • Harald Ulriksen 207 posts 249 karma points
    Jan 13, 2010 @ 19:37
    Harald Ulriksen
    Custom fieldtype with hidden input
    The asp.net hiddenfield does not implement webcontrol, but control, so it's not possible to create a fieldtype with it. I've tried putting it in a panel, but the panel is not properly rendered by contour as it seems to remove the div.
    Currently I'm using input with css styling to hide it, but I would like to use a proper input type hidden. Any suggestions?
  • Richard Soeteman 4054 posts 12927 karma points MVP 3x
    Jan 14, 2010 @ 06:04
    Richard Soeteman
    Sometimes I think the asp.net teams in Redmond don't talk to each other. I also don't know Contour well enough, but if it's depended on a the webcontrol base class I would create a custom asp.net control and implement the hidden input field in that control. Just a few lines of .net code...
    Richard
    Jan 14, 2010 @ 13:08
    Harald Ulriksen
    Excellent, so busy building my own fieldtype that I didn't think of rolling my own webcontrol. Thanks.
  • Jason Prothero 422 posts 1243 karma points MVP 2x c-trib
    May 20, 2010 @ 22:38
    Jason Prothero
    Any chance you could add your hidden field custom fieldtype as a package?
