  • Sean Dooley 289 posts 528 karma points
    Apr 21, 2015 @ 18:21
    Sean Dooley
    Minimum selection of options in checkboxlist
    Using Umbraco Forms, is it possible to ensure a user selects a minimum of 3 options in a checkboxlist?
    Is this something Umbraco Forms can do out of the box or does this require custom coding?
    Apr 21, 2015 @ 19:20
    Dennis Aaen
    Hi Sean,
    It's possible to set the checkboxlist as mandatory, but I donĀ“t think it is possible to say that you need to choose at least x options on the checkbox list. Perhaps this post https://our.umbraco.org/forum/umbraco-pro/contour/45716-Contour-validate-checkbox-2-items-checked, on how to ensure that is chosen two items, in the checkbox with Contour can give you some inspiration, to a solution for Umbraco Forms.
    If you think it could be a nice featureto have in the future, then you can submit a feature request http://issues.umbraco.org/issues/CON, then the Umbraco HQ will have a look at it, and maybe implement it into future versions of Umbraco Forms.
    Hope this helps,
    /Dennis
