  • Crawford Tait 11 posts 64 karma points
    Apr 24, 2015 @ 11:24
    Crawford Tait
    Forms 4.1 - migrated forms become uneditable, possibly after a submission
    I migrated a multi-page Contour form successfully and was able to edit it to add prevalues back in etc, I also got the front end rendering working and everything was fine. However, on 2 or 3 occasions now, when I return to edit the form I find an error being thrown. I previously put this down to some glitch and re-migrated the form, but it happens repeatedly - I think possibly after the form has been submitted in the front end?
    Error is:
    System.Data.SqlClient.SqlException (0x80131904): Incorrect syntax near the keyword 'order'.
       at System.Data.SqlClient.SqlConnection.OnError(SqlException exception, Boolean breakConnection, Action`1 wrapCloseInAction)
       at System.Data.SqlClient.TdsParser.ThrowExceptionAndWarning(TdsParserStateObject stateObj, Boolean callerHasConnectionLock, Boolean asyncClose)
       at System.Data.SqlClient.TdsParser.TryRun(RunBehavior runBehavior, SqlCommand cmdHandler, SqlDataReader dataStream, BulkCopySimpleResultSet bulkCopyHandler, TdsParserStateObject stateObj, Boolean& dataReady)
       at System.Data.SqlClient.SqlDataReader.TryConsumeMetaData()
       at System.Data.SqlClient.SqlDataReader.get_MetaData()
       at System.Data.SqlClient.SqlCommand.FinishExecuteReader(SqlDataReader ds, RunBehavior runBehavior, String resetOptionsString)
       at System.Data.SqlClient.SqlCommand.RunExecuteReaderTds(CommandBehavior cmdBehavior, RunBehavior runBehavior, Boolean returnStream, Boolean async, Int32 timeout, Task& task, Boolean asyncWrite, SqlDataReader ds)
       at System.Data.SqlClient.SqlCommand.RunExecuteReader(CommandBehavior cmdBehavior, RunBehavior runBehavior, Boolean returnStream, String method, TaskCompletionSource`1 completion, Int32 timeout, Task& task, Boolean asyncWrite)
       at System.Data.SqlClient.SqlCommand.RunExecuteReader(CommandBehavior cmdBehavior, RunBehavior runBehavior, Boolean returnStream, String method)
       at System.Data.SqlClient.SqlCommand.ExecuteReader(CommandBehavior behavior, String method)
       at System.Data.SqlClient.SqlCommand.ExecuteReader(CommandBehavior behavior)
       at Microsoft.ApplicationBlocks.Data.SqlHelper.ExecuteReader(String connectionString, CommandType commandType, String commandText, SqlParameter[] commandParameters)
       at umbraco.DataLayer.SqlHelpers.SqlServer.SqlServerHelper.ExecuteReader(String commandText, SqlParameter[] parameters)
       at umbraco.DataLayer.SqlHelper`1.ExecuteReader(String commandText, IParameter[] parameters)
    Apr 24, 2015 @ 13:34
    Crawford Tait
    Seems to be intermittent!
  • Gerjan 19 posts 78 karma points
    Apr 24, 2015 @ 14:30
    Gerjan
    I just happen to have the same error after i made a form (using Umbraco 7.2.4 Forms 4.1) with a worfklow action to create a node when Approved...
    After a test entry and approvel i get that error too.
    //edit, after i made another test entry (this time with correct SMTP settings), it works again.. Strange
    Apr 29, 2015 @ 13:19
    Gerjan
    Hi Crawford did you get any answer somewhere?
    Apr 29, 2015 @ 14:52
    Crawford Tait
    No, but I noticed the saem as you - if I submit another entry it went away, not sure if it's toggling on form submissions!
  • Comment author was deleted
    May 06, 2015 @ 09:28
    Hey,
    Would it be possible to send me a copy of the site that is having the issue (tg at umbraco dot com) since I can't reproduce at the moment and would love to solve this bug
    May 07, 2015 @ 21:49
    Gerjan
    Hi Tim,
    What files etc do you need? All web files + db?
    May 08, 2015 @ 10:22
    Yup but you can exlude /media and /app_data/temp , thanks
