  • Ron G 41 posts 137 karma points
    Apr 28, 2015 @ 23:25
    Ron G
    Long Umbraco Forms
    Is there a way to split a long form into multiple screens/pages?
    Thanks!
    Apr 28, 2015 @ 23:40
    Dennis Aaen
    Hi Ron,
    Yes, you can split a form into multiple pages. Try to see the documentation about how to add fields to your form https://our.umbraco.org/documentation/Products/UmbracoForms/Editor/Creating-a-Form/#Addingfields
    In addition to the different field types, you also have the options to make rows, columns, and pages, And to make form into multiple pages, just choose the page option everytime you need a step in your form, and on each page you can add input fields to it.
    Just scroll all the way down when you add a new field to your form, then you will see the rows, columns, and pages option
    Hope this helps,
    /Dennis
