Umbraco contour form entries pagination not working
Hi All,
I got a contour form with 15 entries, and when I view the form entries, it is showing the first page of 10 entries. However, after I click "Next" or "Last" the listing items do not change. It is still showing the first page.
However, the label is changed to "Showing 11 to 15 of 15 entries", but the actual listing does not change.
When I check the log file, there is following entry,
2015-05-05 22:05:05,581 [198] WARN
Umbraco.Web.Dictionary.DefaultCultureDictionary - [Thread 214] Error
returning dictionary item 'Next'. Exception: System.ArgumentException:
No key Next exists in dictionary at
umbraco.cms.businesslogic.Dictionary.DictionaryItem..ctor(String key)
at Umbraco.Web.Dictionary.DefaultCultureDictionary.get_Item(String
key)
Please help me fix this. Is it contour bug? Is the form entries pagination working for anyone else? Thanks.
Umbraco version - 7.1.8
Contour version - 3.0.23-Build.20
I couldn't find a specific issue on this in the change log http://nightly.umbraco.org/Umbraco%20Contour/changes.txt, but, you are using an older version of Contour. Is it an option for you to upgrade it to the latest version of Contour to see if it´s still a problem.
The latest version of Contour at the moment is Contour 3.0.27 you can download the latest version here https://our.umbraco.org/projects/umbraco-pro/contour by clicking the green download button on the right side of the page.
Yup like Dennis mentoins, please upgrade to the latest stable release, the error you are getting isn't related to the entries viewer.... if upgrading doesn't fix the issue please let us know
thanks for the advise. however, after upgrading to the latest contour version, the issue is still there and not fixed. is the pagination working for you guys?
Hi All,
Umbraco version - 7.1.8 Contour version - 3.0.23-Build.20
Hi Zar,
Upgrading documentation for Contour can you find here: https://our.umbraco.org/projects/umbraco-pro/contour/documentation/Installation/Upgrade
Hope this helps,
/Dennis
Comment author was deleted
Yes pagination is working fine, would you mind sending a copy of your site to tg at umbraco dot com? I can then debug and fix the issue for you
I had a report from my client with the same issue, after updating to the latest umbraco and latest contour forms it is still not working correctly.
