  • Gal Nitzan 50 posts 164 karma points
    May 12, 2015 @ 20:35
    Gal Nitzan
    All node are missing on contour after upgrade to 3.0.27 (on 6.2.5
    It seems like all the nodes are missing on the left panel. Only the Contour node is visible and reload nodes doesn't do anything.
    I can see the forms on the right panel with no problem to edit/create etc.
    However I need the context menu on the left.
    Any urgent advice would be really appreciated.
    BR,
    Gal.
    May 12, 2015 @ 21:16
    Dennis Aaen
    Hi Gal,
    Perhaps you could try to see if everthing is in place. If you see the guide for an manual install https://our.umbraco.org/projects/umbraco-pro/contour/documentation/Installation/Manual
    As you can see there some config files that needs some data /config/dashboard.config and /umbraco/config/create/ui.xml. could you please check that these files in your installation contains the data described in the documentation.
    Maybe it would be a good idea to take a backup of the database and the file systemt before you are trying this.
    Hope this helps,
    /Dennis
    May 13, 2015 @ 05:35
    Gal Nitzan
    Hi Dennis,
    Thank you for your quick reply.
    I just finished going thru the manual install, done everything in the text/ made sure every thing is in place and it seems that way.
    However, my left hand side panel is still empty (only the root node as in the image)
    BR,
    Gal.
    May 13, 2015 @ 05:49
    Hi Gal
    What does your /config/trees.config file look like? Can you post the content in here please.
    May 13, 2015 @ 06:48
    Gal Nitzan
    <trees>
      <!--Content-->
      <add application="content" alias="content" title="Content" type="umbraco.loadContent, umbraco" iconClosed=".sprTreeFolder" iconOpen=".sprTreeFolder_o" silent="true" sortOrder="0" />
      <add application="content" alias="contentRecycleBin" title="RecycleBin" type="umbraco.cms.presentation.Trees.ContentRecycleBin, umbraco" iconClosed="folder.gif" iconOpen="folder_o.gif" initialize="false" sortOrder="0" />
      <!--Media-->
      <add application="media" alias="media" title="Media" type="umbraco.loadMedia, umbraco" iconClosed=".sprTreeFolder" iconOpen=".sprTreeFolder_o" sortOrder="0" />
      <add application="media" alias="mediaRecycleBin" title="RecycleBin" type="umbraco.cms.presentation.Trees.MediaRecycleBin, umbraco" iconClosed="folder.gif" iconOpen="folder_o.gif" initialize="false" sortOrder="0" />
      <!--Settings-->
      <add application="settings" alias="stylesheets" title="Stylesheets" type="umbraco.loadStylesheets, umbraco" iconClosed=".sprTreeFolder" iconOpen=".sprTreeFolder_o" sortOrder="0" />
      <add application="settings" alias="stylesheetProperty" title="Stylesheet Property" type="umbraco.loadStylesheetProperty, umbraco" iconClosed="" iconOpen="" initialize="false" sortOrder="0" />
      <add application="settings" alias="templates" title="Templates" type="umbraco.loadTemplates, umbraco" iconClosed=".sprTreeFolder" iconOpen=".sprTreeFolder_o" sortOrder="1" />
      <add application="settings" alias="partialViews" title="Partial Views" silent="false" initialize="true" iconClosed=".sprTreeFolder" iconOpen=".sprTreeFolder_o" type="Umbraco.Web.Trees.PartialViewsTree, umbraco" sortOrder="2" />
      <add application="settings" alias="scripts" title="Scripts" type="umbraco.loadScripts, umbraco" iconClosed=".sprTreeFolder" iconOpen=".sprTreeFolder_o" sortOrder="3" />
      <add application="settings" alias="dictionary" title="Dictionary" type="umbraco.loadDictionary, umbraco" iconClosed=".sprTreeFolder" iconOpen=".sprTreeFolder_o" action="openDictionary()" sortOrder="4" />
      <add application="settings" alias="languages" title="Languages" type="umbraco.loadLanguages, umbraco" iconClosed=".sprTreeFolder" iconOpen=".sprTreeFolder_o" sortOrder="5" />
      <add application="settings" alias="mediaTypes" title="Media Types" type="umbraco.loadMediaTypes, umbraco" iconClosed=".sprTreeFolder" iconOpen=".sprTreeFolder_o" sortOrder="6" />
      <add application="settings" alias="nodeTypes" title="Document Types" type="umbraco.loadNodeTypes, umbraco" iconClosed=".sprTreeFolder" iconOpen=".sprTreeFolder_o" sortOrder="7" />
      <!--Developer-->
      <add application="developer" alias="datatype" title="Data Types" type="umbraco.loadDataTypes, umbraco" iconClosed=".sprTreeFolder" iconOpen=".sprTreeFolder_o" sortOrder="1" />
      <add application="developer" alias="macros" title="Macros" type="umbraco.loadMacros, umbraco" iconClosed=".sprTreeFolder" iconOpen=".sprTreeFolder_o" sortOrder="2" />
      <add application="developer" alias="packager" title="Packages" type="umbraco.loadPackager, umbraco" iconClosed="folder.gif" iconOpen="folder_o.gif" sortOrder="3" />
      <add application="developer" alias="packagerPackages" title="Packager Packages" type="umbraco.loadPackages, umbraco" iconClosed="folder.gif" iconOpen="folder_o.gif" initialize="false" sortOrder="3" />
      <add application="developer" alias="relationTypes" title="Relation Types" type="umbraco.loadRelationTypes, umbraco" iconClosed=".sprTreeFolder" iconOpen=".sprTreeFolder_o" sortOrder="4" />
      <add application="developer" alias="python" title="Scripting Files" type="umbraco.loadPython, umbraco" iconClosed="folder.gif" iconOpen="folder_o.gif" sortOrder="4" />
      <add application="developer" alias="xslt" title="XSLT Files" type="umbraco.loadXslt, umbraco" iconClosed=".sprTreeFolder" iconOpen=".sprTreeFolder_o" sortOrder="5" />
      <add application="developer" alias="partialViewMacros" type="Umbraco.Web.Trees.PartialViewMacrosTree, umbraco" silent="false" initialize="true" sortOrder="6" title="Partial View Macro Files" iconClosed=".sprTreeFolder" iconOpen=".sprTreeFolder_o" />
      <!--Users-->
      <add application="users" alias="users" title="Users" type="umbraco.loadUsers, umbraco" iconClosed=".sprTreeFolder" iconOpen=".sprTreeFolder_o" sortOrder="0" />
      <add application="users" alias="userTypes" title="User Types" type="umbraco.cms.presentation.Trees.UserTypes, umbraco" iconClosed=".sprTreeFolder" iconOpen=".sprTreeFolder_o" sortOrder="1" />
      <add application="users" alias="userPermissions" title="User Permissions" type="umbraco.cms.presentation.Trees.UserPermissions, umbraco" iconClosed=".sprTreeFolder" iconOpen=".sprTreeFolder_o" sortOrder="2" />
      <!--Members-->
      <add application="member" alias="member" title="Members" type="umbraco.loadMembers, umbraco" iconClosed=".sprTreeFolder" iconOpen=".sprTreeFolder_o" sortOrder="0" />
      <add application="member" alias="memberGroup" title="Member Groups" type="umbraco.loadMemberGroups, umbraco" iconClosed=".sprTreeFolder" iconOpen=".sprTreeFolder_o" sortOrder="1" />
      <add application="member" alias="memberType" title="Member Types" type="umbraco.loadMemberTypes, umbraco" iconClosed=".sprTreeFolder" iconOpen=".sprTreeFolder_o" sortOrder="2" />
      <!--Translation-->
      <add silent="false" initialize="true" sortOrder="1" alias="openTasks" application="translation" title="Tasks assigned to you" iconClosed=".sprTreeFolder" iconOpen=".sprTreeFolder_o" type="umbraco.loadOpenTasks, umbraco" action="" />
      <add silent="false" initialize="true" sortOrder="2" alias="yourTasks" application="translation" title="Tasks created by you" iconClosed=".sprTreeFolder" iconOpen=".sprTreeFolder_o" type="umbraco.loadYourTasks, umbraco" action="" />
      <!-- Custom -->
      <!--<add application="myApplication" alias="myTree" title="Me Tree" type="MyNamespace.myTree, MyAssembly"
           iconClosed=".sprTreeFolder" iconOpen=".sprTreeFolder_o" sortOrder="10" />-->
      <add silent="false" initialize="true" sortOrder="0" alias="repositories" application="courier" title="Repositories" iconClosed="legacy" iconOpen="legacy" assembly="Umbraco.Courier.UI" type="Trees.LoadRepositories" action="" />
      <add silent="false" initialize="true" sortOrder="1" alias="revisions" application="courier" title="Revisions" iconClosed="legacy" iconOpen="legacy" assembly="Umbraco.Courier.UI" type="Trees.LoadRevisions" action="" />
      <add silent="false" initialize="true" sortOrder="5" alias="courierSecurity" application="users" title="Courier security" iconClosed="legacy" iconOpen="legacy" assembly="Umbraco.Courier.UI" type="Trees.LoadCourierSecurity" action="" />
      <add silent="false" initialize="true" sortOrder="2" alias="taskmanager" application="courier" title="Task manager" iconClosed="legacy" iconOpen="legacy" assembly="Umbraco.Courier.UI" type="Trees.LoadTaskManager" action="" />
      <add silent="false" initialize="true" sortOrder="6" alias="robotsTxt" application="developer" title="Robots.txt" iconClosed="../../robots-txt/robot.png" iconOpen="../../robots-txt/robot.png" assembly="Our.Umbraco.Tree.RobotsTxt" type="RobotsTxtTree" action="" />
      <add silent="false" initialize="true" sortOrder="0" alias="forms" application="contour" title="Forms" iconClosed="legacy" iconOpen="legacy" assembly="Umbraco.Forms.UI" type="Trees.LoadForm" action="" />
      <add silent="false" initialize="true" sortOrder="1" alias="formdatasources" application="contour" title="Data Sources" iconClosed="legacy" iconOpen="legacy" assembly="Umbraco.Forms.UI" type="Trees.LoadDataSource" action="" />
      <add silent="false" initialize="true" sortOrder="2" alias="formprevaluesource" application="contour" title="Prevalue Sources" iconClosed="legacy" iconOpen="legacy" assembly="Umbraco.Forms.UI" type="Trees.LoadPreValueSource" action="" />
      <add silent="false" initialize="true" sortOrder="5" alias="formssecurity" application="users" title="Contour security" iconClosed="legacy" iconOpen="legacy" assembly="Umbraco.Forms.UI" type="Trees.LoadFormsSecurity" action="" />
      <add initialize="true" sortOrder="100" alias="FALMHousekeeping" application="developer" title="FALM Housekeeping" iconClosed=".sprTreeFolder" iconOpen=".sprTreeFolder" type="FALMHousekeeping.loadHousekeeping, FALMHousekeeping" />
    </trees>
    May 13, 2015 @ 08:27
    Hi Gal
    Ok, I think you should try changing these lines from
    to
    <add silent="false" initialize="true" sortOrder="0" alias="forms" application="contour" title="Forms" iconClosed="legacy" iconOpen="legacy" assembly="Umbraco.Forms.UI, Trees.LoadForm" action="" />
      <add silent="false" initialize="true" sortOrder="1" alias="formdatasources" application="contour" title="Data Sources" iconClosed="legacy" iconOpen="legacy" assembly="Umbraco.Forms.UI, Trees.LoadDataSource" action="" />
      <add silent="false" initialize="true" sortOrder="2" alias="formprevaluesource" application="contour" title="Prevalue Sources" iconClosed="legacy" iconOpen="legacy" assembly="Umbraco.Forms.UI, Trees.LoadPreValueSource" action="" />
      <add silent="false" initialize="true" sortOrder="5" alias="formssecurity" application="users" title="Contour security" iconClosed="legacy" iconOpen="legacy" assembly="Umbraco.Forms.UI, Trees.LoadFormsSecurity" action="" />
    I suspect that is the issue - If you compare the last line where the FALMHousekeeping tree is defined you can see that this line is different (And I'm assuming it's working correctly). So therefore I think doing it like displayed above will fix the issue.
    The F.A.L.M housekeeping package setting
    Make sure to recycle the app pool afterwards - and make a backup of the file before making the changes so it's easy to rollback in case this is not the solution. Please notice how the value from the "type" attribute has been moved into the "assembley" attribute after the comma - When the value is copied over you can leave the "type" attribute empty or remove it.
    Hope this helps!
    May 13, 2015 @ 08:42
    Gal Nitzan
    Hi Jan,
    Thank you for all the help.
    Did the change and I get the exception:
    [ArgumentNullException: Value cannot be null.
    Parameter name: typeName]...
    Gal.
    May 13, 2015 @ 08:51
    Dennis Aaen
    Hi Gal,
    Could it be something similar to this that you are experience try to see this http://issues.umbraco.org/issue/U4-6327 issue maybe it can help you solve your issue with Contour.
    Hope this helps,
    /Dennis
    May 13, 2015 @ 08:52
    Gal Nitzan
    101
    Hi Jan,
    You lead me to the right track. I have a U7 site which I currently use to upgrade the current U6 site and there is no problem there with Contour.
    I copied the entries from the U7 trees.config and now all is as expected.
    Much obliged..
    All the best,
    Gal.
    Just in any case someone needs the correct lines U6.2.5/U7.2.4:
      <add initialize="true" sortOrder="0" alias="forms" application="contour" title="Forms" iconClosed="legacy" iconOpen="legacy" type="Umbraco.Forms.UI.Trees.LoadForm,Umbraco.Forms.UI" />
      <add initialize="true" sortOrder="1" alias="formdatasources" application="contour" title="Data Sources" iconClosed="legacy" iconOpen="legacy" type="Umbraco.Forms.UI.Trees.LoadDataSource,Umbraco.Forms.UI" />
      <add initialize="true" sortOrder="2" alias="formprevaluesource" application="contour" title="Prevalue Sources" iconClosed="legacy" iconOpen="legacy" type="Umbraco.Forms.UI.Trees.LoadPreValueSource,Umbraco.Forms.UI" />
      <add initialize="true" sortOrder="5" alias="formssecurity" application="users" title="Contour security" iconClosed="legacy" iconOpen="legacy" type="Umbraco.Forms.UI.Trees.LoadFormsSecurity,Umbraco.Forms.UI" />
