Umbraco Forms - Is it possible to use form data in Workflow settings?
Hello again,
Essentially I'm looking to take the recipient address in the email workflow from the a field on the form itself.
I came across an old post by Ismail on Contour which stated that this is possible if you use the bracket syntax and form field label, so for example; the textfield 'Email address' would be
{email address}
however this does not appear to work in the latest Umbraco Forms version.
Is there an acknowledged method of achieving this?
Hello again,
Kind Regards, Chris
Comment author was deleted
Yup it should still work, you have to lower case and remove all special chars (like space) so Email Address becomes {emailaddress}
Sorted, thanks Tim!
