I am running Umbraco Forms 4.0.1 and I now want to upgrade to 4.1.1. But there is no "Upgrade now" button showing on the dashboard.
The guide on https://github.com/umbraco/UmbracoFormsDocumentation/blob/master/Installation/index.md on how to "Keeping Forms up to date" returns a 404-message.
How can I upgrade Forms manually?
Regards, /Martin
Hi Martin,
Simply download the files here: http://nightly.umbraco.org/UmbracoForms/4.0/UmbracoForms.Files.4.1.1.zip
Extract and replace the existing files.
Regards, Chris.
Thanks Chris, I will try this.
Now the replacement of files makes sense using your provided download link. The package files I first downloaded from https://our.umbraco.org/projects/developer-tools/umbraco-forms does not come with folder/files structure.
//martin
No worries,
I was stuck on this point too, it was Tim who eventually pointed me in the right direction!
Chris.
How do I manually upgrade Umbraco Forms ?
Regards, /Martin
Hi Martin,
Regards, Chris.
//martin
No worries,
Chris.
