I have upgraded contour to 3.0.26 and when i try to click a folder in the contour tree i get a 404 that the above said file is missing (yes, it is, obviously) but i cannot find it in any package either which makes me think i have some other issue regarding my installation.
missing views/forms/edit.html
(edit: the umbraco installation is 7.2.4)
Any suggestions appreciated :)
Comment author was deleted
Hey,
Could you see if the /config/dashboard.config contains any Contour related entries?
Hi Tim
Yep, looks lite this:
<section alias="contour"> <areas> <area>contour</area> </areas> <tab caption="Dashboard"> <control>/umbraco/plugins/umbracocontour/formsdashboard.ascx</control> </tab> </section>Regards
Patrick
Hmm not sure what is wrong then since you should just get the dashboard, will check if it's a bug in 7.2.4
