  • Michael 125 posts 409 karma points
    May 20, 2015 @ 13:39
    Michael
    Contour db cleanup
    I need to clean all records from contour db which older than some date (2 month).
    Who can help me to re-factor this
    IF (OBJECT_ID('ContourRemoveRecords') IS NOT NULL)
      DROP PROCEDURE ContourRemoveRecords
    GO
    Create PROCEDURE [ContourRemoveRecords]
        @date datetime = NULL
    AS
    BEGIN
           create table #RecordsFormsGuids (
        RecordId nvarchar(36)
    create table #RecordsKeys (
    INSERT INTO #RecordsFormsGuids
    Select Id  FROM [dbo].[UFRecords] where Created < Convert(datetime, @date)
    DELETE FROM  [dbo].[UFRecords] where Created < Convert(datetime, @date)
    DELETE FROM [dbo].[UFRecordsXml] where Created < Convert(datetime, @date)
    Insert INTo #RecordsKeys
    SELECT [Key]
    FROM [dbo].[UFRecordFields] Where Record in
    Select * from #RecordsFormsGuids
    DELETE FROM [dbo].[UFRecordFields] Where Record in
    DELETE
      FROM [dbo].[UFRecordDataString] Where [Key] in
    Select * from #RecordsKeys
    Drop Table #RecordsFormsGuids
    Drop table #RecordsKeys
    END
  • Chris Wilson 100 posts 377 karma points
    May 20, 2015 @ 15:47
    Chris Wilson
    It would be much cleaner if you could perform this through the Contour library singleton or a RecordStore instance, that way the library code will clean all linked records for you.
    Do this overnight of course :)
    May 21, 2015 @ 09:57
    Michael
