Suddenly contour stopped working and stuck on endless "Processing..."
I have a costumer with old umbraco site (4.5.2) and Contour.
Everything worked fine until yesterday contour stopped working and stuck on endless "Processing..." when he try to export records from the last 'any option'....
Any Idea?
Comment author was deleted
So the export option in the right corner isn't working anymore since it seems the entries are still shown fine
Or is it stuck in processing when you switch the period (so last any)
Hi Tim,
Second option- It stuck in processing when I switch the period...
Thanks for your help
Ok since you are running a pretty old version I suspect that you are running into a legacy bug so I would advise to upgrade both Umbraco and Contour.
